Question about Motorola Mobility RAZR V3
Master reset on motorola rzr 2
I tried the holding menu, then the zeros- did not work.Anything else I can do??
  • 1 more comment
  • goldengurl May 12, 2008
    Hello
    I still cant get it to reset. There is only the circle with the center button....no menu button.Anythting else we can try?Let me know. Thanks Pattie
  • moni11 Nov 18, 2008
    I set a password for my phone..
    on the settings, messages, and media gallery..
    i forgot my password.. i would like to know how to either
    unlock my phone or master reset it!
    please help!!
    How can i master reset my phone without using my settings..
    my settings are locked.. and forgot my password..
    is there anyother way i can master reset it??
    HELP!!
    Novelist:
  • 124 Answers
HI again,
1st let me tell u. U have to give a frequent try to it.
Its a tricky.
1) The two buttons work as menu buttons. One is in the center of directional keys and second is above the directional keys. U hv to press the second menu button above the directional keys.
2) While holding menu button, a message appears "shortcut not allowed for this item". The change of 4-digits slot to 6-digits slot may be after u do it also. At this time, type 000000 (six zero). Anyway, try it holding menu for 3-4 seconds or by holding it for a little long time.
Looking for ur kind feedback. Dont forget to Rate my solution too.
Be sure to post a clarification request after ur problem is solved.
SAJAN(sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
Posted on May 09, 2008
Cnt unlock or reset mater code on the motorola rokr for metro pcs
Here is how to do a master clear or master reset on most Motorola cell phones.
If you have a Motorola cell phone and want to clear all numbers out of the address book and reset factory settings you need to use the master reset function.
First you need to go to the main menu, settings, setup, master clear option and enter six zeroes, 0000000
This works on most phones. If that does not work call your carrier's technical support
by dialing 611.
Master Reset Codes and Master Clear For Motorola Cellular Phones.
var dc_AdLinkColor = 'blue' ; var dc_PublisherID = 90892 ;
Sep 09, 2009 | Motorola Mobility ROKR E1 Cellular Phone
Motorola Q 9c Start screen blank
master reset mabye
master reset the phone by hold the center key and the power, then follow onscreen instructions
i would try to go to file explorere and backup your contacts yourself, or take it in
May 30, 2009 | Motorola Mobility Moto Q
Have a motorola v9. Cant remember the password and need to know how to bypass the lock code so i can master reset the phone and start using it again.
try pressing the menu button when the phone asks for the code than it will change to a security code and the security code is set default to 6 zeros [000000]
Mar 12, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Rzr v3 showing an "Insert SIM" message
if you havent already, try to remove the sim and the battery and reinsert it.....if it still doesnt work, put your sim in another handset. if the issue follows the sim, the sim will need to be replaced. if the problem stays with the phone, attempt a master clear if the handset will let you. (the master clear will reset all phone settings and delete all your info so beware)
go to MENU > SETTINGS > INITIAL SETUP > select MASTER CLEAR
***security code by default is 000000 (6 zeros)***
good luck :)
Jan 28, 2009 | Motorola Mobility RAZR V3
Razor shuts off by itself
your probly right.....its either corupt software of a battery issue....try the obvious first (remove and reinsert the battery if you havent already)....if that fails, try the master reset.
MENU > SETTINGS > INITIAL SETUP > MASTER RESET
**default code is 000000 (6 zeros)**
if THAT doesnt work, try a different battery. you can pick them up cheap if you dont have one lying around from www.amazon.com or www.shopmotorola.com
if thats not an option, try a master clear. if you dont want to buy anything, i would try this first. the master reset just sets everthing back to manufacturers default.....the clear DOES. you will LOOSE EVERYTHING INSTALLED ON THE PHONE MEMORY.
to do this, go to MENU > SETTINGS > INITIAL SETUP > MASTER CLEAR
**again, default code is 000000 (6 zeros)**
good luck :)
Jan 26, 2009 | Motorola Mobility RAZR V3
Motorola MOTORAZR² V9m
Go to Menu/settings/initial setup/master reset enter 6 zero ok.
Similar Menu/setting/initial setup/master clear enter 6 zero ok.
Before to do that function,copy all phone book to simcard.
Dec 26, 2008 | Verizon Communications Motorola MOTORAZR2...
Motorola format
go to MENU then SETTINGS then INITIAL SETUP then MASTER RESET (000000) OK.
Nov 10, 2008 | Motorola Mobility L6 Cellular Phone
Master reset
moz-screenshot-1.jpgmoz-screenshot-2.jpgHI dude,
to bypass the security, i hv got a trick.
When u r asked for security code,
press menu button(above the directional keys) for 3-4 seconds. if u hv done properly the gap for 4 digits will be changed to 6 digits slot. Now enter 000000 (six zero). now u will bypass the security code. By same process u can change or reset security code from settings.
May 06, 2008 | Motorola Mobility RAZR V3
Mobile blocked
is it asking for unlock code? if it is and u didn't change the security code u only need to press the menu button wen its askin for the unlock code n enter 6 zeros (000000)
Nov 08, 2007 | Motorola Mobility RAZR V3
TEXT SCREEN FREEZES
T-Mobil master reset is 000000 (6 zeros)
Sep 16, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
466 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
