Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Thanks I ordered new stk392-120's and all new resistors! I will cross reference all parts myself from now on. Thanks again!
  • 121 Answers
Your very welcome if you need any more help let me know
Posted on May 08, 2008
Ngk cross reference chart
I recommend only H-D plugs myself.
Check electrode gap with a wire-type feeler gauge. Bend
the outside of the electrode so that only a slight drag is felt on the
gauge as it passes between the electrodes. The proper
gap measurement is 0.038-0.043 in. (0.97-1.09 mm).
May 07, 2014 | 2001 Harley Davidson FXDXT Dyna Super...
K5-A model only runs on high no matter what speed set to
you can try opening it up and ordering a control board for that particular board,most companies won't sell you what they call an "internal part" due to liability with electrical parts,if you can get to the board you will find the s.c.r//triac/or diac shorted on the board and you need to replaced,it may show burned spots on the board from the component shorting,if you can cross reference the part great,but it may have a company part number and these do not cross reference
Jul 24, 2010 | KitchenAid 32685 Mixer
Dremel Model 800, 10.8v Lithium-Ion cordless Tool voltage reg.
Read off the identity on the regulator. That is the part number to order from an electronics outlet.
Feb 24, 2018 | Dremel Saws
Convergence problem ,Help Please
Something is not right here. Is there any possibility that you can get the circuit designation (Rxxx) of the resistors that were "incorrect"? I am not aware of anything like this that can cause the "memory to be erased". The only memory in that area would be the factory convergence settings which can be modified from the service menu. Please try to supply the resistor IDs and I'll check on this.
Thanks,
Dan
Feb 13, 2009 | Panasonic PT-51HX41 51" Rear Projection...
BLOWN RESISTORS
you can download your schematic that will tell you resistor values and the rest of the circuits and IC indentifications as well as test procedures and more , this is a ten part zip that can be opened with winzip and read with adobe just click here http://www.eserviceinfo.com/downloadsm/12926/Hitachi_50FX30B.html
then to order resistors you can get them here http://www.nteinc.com/
or look for an electronic parts supply store around you , but alot of the time they too have to order the parts, ecspecially certain valued resistors or other special valued parts
if you need more help just ask !
Dec 11, 2008 | Hitachi 60FX32B 60" Rear Projection...
Blurry shadows in red and teal.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Picture look double and the colors red come out the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence Resistors
Can you check that location number again The parts list doesnt list a capacitor with that location number. Is the item a resistor or a capacitor ? Let me know the other site I work at has full service manuals with part numbers and specs in them. I will be able to tell you the specs on your part
Mar 24, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Mitsubishi WS 65511 convergence
Go on line and get an original Sanyo STK 393-110. Next, restore the blue centering rings back to where they were before you moved them. Look at the paint marks on the rings for reference if you are not sure. Replace the IC and check the resistors nearby for signs of overheating and proper value. Also check the fuses that supply the 24v to the IC. The service manual will show you the fuse location and give you the resistor values in the blue horizontal and vertical circuit. Checklist: You need a de-soldering tool or a good quality Dry Wick. Have a small tube of heat sink compound to liberally apply to the new chip. The hardest part will be lining up the double rowed pins on the chip and getting them to seat at the same time. Next, go to the convergence menu and follow the instructions. Good luck! PS you might want to remove the chassis from the cabinet to make it easier. Be careful to unplug the speaker plug and untwist the wire ties from the cabinet. Be very careful, this job is not designed for beginners.
Mar 24, 2008 | Mitsubishi WS-65511 65" Rear Projection...
RCA F27442 27" TV
1) Ask what the part location on the board is = IC301 for example..
2) Provide service #
3) Could be LA7612N
4) If they were not blowing smoke,why didn't they give you a
six digit RCA part # ??
....................................................T.
Nov 09, 2007 | RCA 32V420T 32" TV
R7048 (2,2R)
Is it impossible to read the colors or markings on the resistor? If not, acquire your resistor from any electronics parts house...accordianman
Nov 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
