Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
The dryer runs, but absolutely no heat. - Whirlpool LTE6234D Top Load Stacked Washer/Dryer
    Scholar:
  • 97 Answers
Look in the back and see if the heat box come lose this can happen from moving the machine as well as lots of use the heat box usually is held in place with a spring binders they can break but you can fix with a spring from the hardware store older machines have this issue as well as out of balance machine combos not all units have this set up but it is a start make sure it is unplugged before working on it hope this helps
Posted on Aug 30, 2010
Lg dryer dlex3360v runs but does not heat
The reason why it runs with no heat is because the heater coil has just gone out you need to replace your heater coil in your dryer and then it'll work
Feb 07, 2018 | LG Dryers
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
Our dryer is a little over a year old. Everything seems like its running ok except for the fact that there is absolutely no heat. Any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | LG DLE2512W Electric Dryer
Just replaced the heating element to my Kenmore dryer...still no heat. Does this sound like the thermostat sensor on the side of the element housing is defective?
Absolutely; Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer, on the blower or along side of the heater box. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
  • Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Aug 25, 2010 | Kenmore Dryers
There is no heat
Check the exhaust vent tubing throughout. If clogged up with lint the sensor will shut the heating completely off all the time till cleaned
May 08, 2010 | Kenmore 62602 Electric Dryer
Ignitor? dryer runs through cycles, but NO heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
gfgf
Oct 16, 2009 | GE DBL333GB Gas Dryer
My dryer has no heat adn will run all night
If it's sensor dryer then it's absolutely normal to run all the night, as it stops only when the load is dry. And for the heating Take the unit apart and check the heating element.
If you need more info give model detail.
Good luck
Jul 05, 2009 | Dryers
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
Sal De
Gerry Harvey
Gerry Harvey
