Question about Royal 150MX Cross-Cut Shredder
Drive gear from motor is stripped,need a new gear
    Genius:
  • 1,218 Answers
Give Royal a call at 1-800-524-0799 for parts assistance.
Posted on Aug 31, 2010
Wipers jammed half way up but motor still going and maiking a noise
Possibly the gear inside the moyor is stripped.. OR The drive shaft at the motor is stripped or disconnected. .. stripped drive shaft most possible.
May 26, 2014 | 2005 Audi A3
My gear will turn without having the chain on . When chain is attached it the motor just works. No chain movement
I wasn't familiar with your saw but I looked at the parts diagram for it in the link below thinking there may be a replaceable drive pin or something like it that would possibly have sheared.
http://www.masterparts.net/111409-01.html
I didn't see any. That would indicate that the sprocket may be stripped out on the inside and would require replacement, or, that there is something stripped inside the gearcase. If you look at the diagram, the motor shaft is parallel with the handle. So to drive the sprocket gear that drives the chain, they use gears inside the housing to turn the sprocket that's at a right angle to the motor shaft. Do you follow me? It would appear from the parts diagram that if it is those internal gears, that it would require replacement of the whole motor/gear assembly ...... probably as expensive as a whole new saw!
The reason that the sprocket turns without the chain on is that there is evidently enough friction between the shaft that the sprocket mounts on, and, the sprocket. But not enough of a connection to drive the chain.
To check further, leave the saw unplugged, and use your finger to try to turn the sprocket. If it turns by hand like that, it would indicate that something is stripped out as I said. To see if it is the sprocket, remove the "Retaining Ring, 5/16" that is shown in the diagram, and inspect the inside of the sprocket. If that appears good, then it would be an internal problem and probably not worth fixing.
Ed
Oct 31, 2013 | Remington 111409 - 01 6" Branch Wizard...
User manual for brookstone foot massager 257097
the gear for the drive is probably stripped. Get a new gear to replace or get a new massager, probably the later.
Aug 03, 2012 | Brookstone Health & Beauty
The plastic gear that runs off the worm drive from the motor is stripped. Where can I get a new one?
You will have to buy a new motor assy. the plastic gear does not come on its own.
Apr 26, 2011 | Office Equipment & Supplies
Blades do not rotate, motor runs
Something is stripped. Most shredders are gear driven from the motor to the driver shaft and onto the driven shaft. Check that the motor has not come loose from its mountings, the drive gear has not come off the motor or the gear has stripped. You will have to split the shredder housings to do this.
Feb 22, 2011 | Fellowes Office Equipment & Supplies
My CDX-636 has a mechanisim to lift and lower the
My Sony CDX-636 has a mechanisim to lift and lower the CD reading carriage. It consists of a small motor and two nylon gears. the smaller of the gears has stripped a number of teeth which makes the carriage move up and then slip back. I need a new gear wheel. where can I buy a new gear? I am living in Palmdale, california
Feb 06, 2010 | Sony CDX-636 CD Changer
First plastic gear driven from motor pinion has
I have a simple solution if you can think outside of the box. When my gear stripped, I chucked away the electrics, and now drive the shredder via a crank handle on the side. It gives good excercise, and isn't difficult to turn with anything up to 6 or so sheets.
If you want to do this, open the machine, and remove the smaller gear at the opposite end of the drive (take off the circlip) to expose a hex shaped shaft. You can also chuck all of the electrics, and all but the two gears that are on the shredder shafts. Then cut a hole through both the top casing, and through the bucket, to line up with the shaft end and allow a 9/16 socket to pass through. When reassembled, there is sufficient room to drive the mechanism with a standard 3/8 drive ratchet, although you could make a fancier drive with a handle on.
Happy Days
Garry
Feb 05, 2010 | Fellowes P400C-2 Shredder
The motor runs but the chain is not turning. what
Take off the cover of the motor unit and you will find the drive gear is stripped. It is white nylon and is just in front of the motor. A new drive gear kit comes with installation instructions.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but blade does not move. Sounds like gear stripped or maybe clutch slipping.
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Jul 17, 2009 | Remington 111409 - 01 6" Branch Wizard...
Royal 150MX Cross-Cut Shredder Logo
121 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
