I have a viore tv and I was wondering how I know whats wrong with it it is making a humming sound the model number is ipt46dl30
  • Steve Allison
    Steve Allison Aug 30, 2010
    Can you determine whether the hum is coming from the speakers or from inside?
    If it is coming from the speakers, a filter capacitor in the power supply for the audio section may be bad.
    Also, if you have a home theater system connected, disconnect it (mark your cables first) to see if the hum changes or goes away; it could be a bad shielded cable between TV and external systems.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 30 Answers
Actually the speakers of your t.v are ruined so you are adviced to get them repaired
Posted on Aug 30, 2010
My 2006 manufactured Viore flat screen plasma tv suddenly went blank. Still have sound. Please help!
Read the following:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
Different TV, but most likely same problem and, in fact, quite possibly literally the same boards, so maybe practically the same TV.
Can't be sure since you haven't posted the model of your Viore.
If you have specific questions, please always include the model number in the question...the model is on a sticker at the back of the TV, right after or below the words "MODEL:" :-)
Nov 09, 2011 | Toymax Viore 42 in. Plasma TV
VIORE TV IPT46DL30 shows no light but power ins going to set??? is there a reset putton???
This tv has no serviceable fuses inside. You may need to replace the power supply module.
Nov 08, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Viore IPT46DL30 has no power, it was working fine and plugged off and then put back to turn on, but noting now , no light and didnt start at all.
Check the output on the wall to make sure you have voltage. If you do then you have a open fuse in the set on the power supply, or the power supply is dead, in the set. You can get a new power supply at www.partstore.com
Oct 16, 2010 | Televison & Video
Viore tv sound but no picture
the sound suddenly stopped working on my Viore 42" plasma.
Aug 17, 2010 | Toymax Viore 42 in. Plasma TV
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Akai 32" flat pannel making a humming sound?
replace the a/v RCA cables to start with and then if you still have a problem, you have loose connecitions on the a/v board
good luck
caypianan@yahoo.com
Dec 29, 2008 | Akai PDP4225M 42 in. Plasma Television
Viore 52' TV randomly shuts off. front lights blink then stop.
I am having the same problem with my PRT50V24D shutting off and blinking lights. After going to viore.com and calling the number listed, I got recording to call another number. When got rep on line I was told it is made by Samsung, Called their tech support and was told that sounds like power problem or bulb getting ready to go. Also if outside of warranty will have to call repair man to see what's wrong. I will have a repair man out next week and will post his results here. Most likely it's the same issue. This is the tech support number for Samsung 1-888-697-2247. Good Luck man. Matt
Dec 05, 2008 | Televison & Video
This is actually a Viore IPT46DL30 That has no Power
If your comfortable remove the back cover and I'm sure you will find a blown main fuse, you can replace it but chances are it will blow again, a new main board should fix it or if your tech savvy you can troubleshoot it yourself, it should be an easy fix with a multi meter
Jan 18, 2018 | Akai PT46DL10 46" HDTV-Ready Television
I have a viore monitor ipt46dl30 which just went black but we can still hear the voice.. help?
I'm in the process of ordering a replacement bulb for a friends set right now. The information below is exactly what's needed to get the correct bulb for this DLP television.
TV Make: Viore
TV Model: IPT46DL30 (Confirmed to be on TV label)
Bulb/Lamp Model: SHP70 (This number is right at the top of the bulb/lamp, where the wires connect)
Housing Model: 140-1027 (This is also known as the Ballast which houses the bulb/lamp)
Now, I've managed to locate the bulb/lamp from a few different sites. Unfortunately, there doesn't appear to be a reputable manufacturer making aftermarket bulbs for this DLP model. The original bulb type is all we have to look forward to. The cheapest price that I've found so far is $120.00. I have also found these particular bulbs for as high as $295.00. Needless to say, I'm going with the former.
http://www.replacementlightbulbs.com/lampshp70.html - $120.00 (Buying)
http://purelandsupply.com/140-1027-Bulb-Akai-DLP-TV-Lamps.html - $277.90 (Too much)
http://www.encompassparts.com/products/?140-1027 - $295.00 (Too much & very skeptical)
Mar 31, 2008 | Televison & Video
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
