Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Dell 1704FPT Flat Screen Monitor USB ports
I can't get them to work - any suggestions?
  • 2 more comments
  • ginechita Aug 11, 2008
    hi, the port of the monitor doesn´t work
    What am i do ?
    the port usb in the pc work only
  • AnnaErika Jan 09, 2009
    I have the same problem. The usb-port on the flat panel doesnt work but when I move the device to the pc`s usb-ports it work.
    Does anyone have a solution for this problem?
    My PC is a dell Dimension 9100 and I have a Dell 2007FP
    Thanks
    /Anna
  • nsilva42 Mar 18, 2009
    My usb ports on the side of my Dell LCD monitor do not work. I plug in a thumb drive ect. and no response. How do I turn these ports on my monitor on?
    Anyone?
  • ramilsayo Apr 10, 2009
    I have the same problem, the problem start when I updated to
    Cypress - Other hardware - HX2LP Kit (3.03.0000.2)
    using windows update.
    Can someone help me.
You need to run the usb to your computer first have you done that
Posted on May 09, 2008
USB ports on monitor do not work
Posted on Jun 22, 2010
Usb ports do not work
I have a 24" Dell monitor with built-in USB and SD sockets. Sometimes I have had problems with these not being responsive. This usually comes down to electrical connection.
You should do these in order, also testing for USB port availability at each step .
#1 is the monitor powered up? (USB is active only when monitor is switched on with power button on front of bezel)
#2 check that the USB cable at both ends is plugged in! (you need electrical connectivity)
#3 check that the USB port on the PC can see another device like a memory stick
#4 check your PC's software (drivers must be loaded and the USB port recognized)
Sep 25, 2012 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Help, can't seem to get the USB ports on my monitor to work again. I have the following dell monitor 1704fpt 17in. running windows XP Pro sp. 2
Since the USB ports on this monitor are just the powered USB Hub, you should try it with another PC if you know for sure that the USB port of the PC taht is feeding this Powered USB Hub on the monitor are OK, also check the cable.
The USB board replacement for thsi will not be woth it. Also check for 5vdc on PIN1 of the USB port.
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%201704FPT/
May 05, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Can I use the USB ports on the left side of my Dell 1704FPT monitor to connect devices? (e.g., Logitech webcam)
yes you can use the usb port but let me tell you one thing very clearly there is problem with these ports either they dont recognize your usb or maybe your monitor screen flickers... so use monitor port with a lot of care and i advised you to atlest read the manual before you do anything.
Jan 08, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Did it work before? It may have lost 5vdc feeding the USB interface board or the USB IC may have gone out, Check to see if pin 1 of the USB has 5vdc on it.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Why don't the ports on the monitor work?
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
May 12, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Dell 1704fpt usb ports: how do you find the
you should not need drivers for a usb port is the cable hooked up ? if so they are probably broken
Nov 27, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704fpt Screen turns white
ok,your monitor has a defective vertical ic.when vertical ic is defective you can see the horizontal line.
Oct 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
2,952 people viewed this question
Alun Cox
