Question about Phase Linear UDV9010 Car DVD Player
Uv8020 what you mean by ground the pink wire
  • 3 Answers
Splice it to the bnlack neg power wire
Posted on Dec 28, 2008
What color wire do i hook the pink wire to
Pink wire is generally the parking brake safety. If you dont want the dvd player to play video while in drive wire it to the ground on your parking brake sensor wire. If you do want it to play video while your driving, wire it directly back to the ground wire on your stereo.
May 15, 2010 | Alpine IVA-D300 Car DVD Player
Door locks do not work
Do they not work from and switch? First, check fuse 5 (30a) which is hot at all times. Then, make sure the drivers door lock has voltage to the black.white wire, if not there is a bad connection between the fuse and black/white wire (the same wire feeds switches on both sides, so find the junction and check from there back to the fuse box). Then check to make sure the other four wires register ground. If the black wires do not, run a new ground to those two wires. If the pink/lt grn-pink/yellow switches do not replace the switch. If you find voltage and ground to the other four wires move to the passenger door switch. both pink/black and pink/orange wires should register ground, and the blk/wht should register voltage. Hold the swirch in one position, one of the ground wires should now register voltage. When the switch is pressed the opposite direction, the voltage should reverse. If you register ground on both sides and voltage but it fails when pressing the switch, replace the switch. If it tests ok, the pink/black=pink/orange wires that feed the locks are losing connection between the locks and switch. You then have to move to the lock closest to you and see which wire does not register. The wires from the passenger switch yo the wire that feeds the locks or the junction where the two meet are bad.
Mar 25, 2010 | 1999 Ford Explorer
Phase linear uv8020
you probably have constant power running the radio. do you have constant and ignition wires from the radio hooked up or did you twist the yellow and red wires together? if this installation was done correctly than you the unit should power off when you turn the ignition off.
Mar 29, 2009 | Audiovox UV8020
Dvd player wont show picture
To fix this issue on the back of the double din touch screen#uv8020, splice the pink wire, and splice into the (black) ground wire connecting them together. This will enable you to watch dvd;s whie driving.
Jan 22, 2009 | Phase Linear UDV9010 Car DVD Player
Lost wire harness for uv8020
ebay sells alot of wire harness or I'm sure you can call the company who built it good luck......
Jan 11, 2009 | Audiovox UV8020
No remote....
you mean you are trying to pladvd's while driving??? if you are here you go thae the pink wire form the uv8020 splice it iwith the black wire neg power wire. and that should work if yo uneed picturs just let me know montoyafam1@cox.net
Nov 29, 2008 | Phase Linear UDV9010 Car DVD Player
Phase linear vu8020
put the pink wire to the ground wire and it will play video all the time.
Oct 27, 2008 | Audiovox UV8020
Jensen double din dvd monitor uv8020
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Sep 11, 2008 | Jensen VM9510 Car DVD Player
Brake bypass code
I just got this same unit on thursday of last week and put it in myself. All you have to do is ground the pink wire out and it will work without having to put a bypass code in. Hope this works for you as well.
Mar 31, 2008 | Phase Linear UDV9010 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Phase Linear UDV9010 Car DVD Player Logo
88 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
