Question about EnGenius EOC-3220 (EOC3220)
How do I get into my engenuis eco-3220? Someone messed with the ip address and I cant figure it out at all...or it will let me ping then not let me ping...going crazy
  • 481 Answers
There is no reset button on this model. To forcibly regain control of the configuration, you need a USB to serial cable, possibly a null modem adapter (depending on the serial cable), and a serial communication program like HyperTerminal or ZTerm for the Mac.
The manufacturer has incomprehensibly removed the detailed reset instructions from their website, but they can be found here:
http://www.keenansystems.com/engenius__senao_wifi_faq.htm
Look for the section titled "How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? "
Posted on Oct 27, 2010
Ping ip address
I think there may be a connection problem from your side or in that ip address you pining.So better reset the modem or router then ping it.
To ping ip address you can use method in windows XP.
Goto start-run-command prompt-Ping ip address
For example: Ping 55.253.12.86
You can ping ip address or website using the site Whoisxy.com
May 21, 2013 | Computers & Internet
Well i have a dell latitude d600 and i can get the wifi connection on my computer but cant connect to the internet whats going on
if u know the IP address of your router and ur servicve provider's server IP then ping it....
go to Start/Run
in the next window type this
ping 198.168.1.1 -t (the number is the IP address of ur router...replace the number written by me with ur router number)
ping 59.179.243.70 -t (the number here is the IP address of internet service provider server...replace the number written by me with one for your internet service provider server IP address)
the ping window will be a DOS window with responce from the respective server/router with milli seconds mentioned as responce time....if that comes then ur connection is ok
for further info check with ur internet provider
Feb 18, 2010 | Dell Inspiron 1501 Notebook
Conect to network
you have to setup in printer menu option
network settings
-> TCP/IP settings
-> IP address
-> subnet mask
-> Gateway address
and ping the ip of pirnter form pc and install the driver .
Jan 28, 2010 | Office Equipment & Supplies
Cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
May 02, 2009 | EnGenius EOC-3220 (EOC3220)
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
Eoc3220+ ip finder
hi
reset your eoc 3220 and put the default ip address is 192.168.1.254 bridge mode and ad mode ip is 192.168.1.253 and put your pc ip 192.168.1.10,12,14,16 and open the web page and browse the 192.168.1.254 or 192.168.1.253 put user name and password ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | EnGenius EOC-3220 (EOC3220)
Getting to setup pages
look at your DHCP client table on your router to find the IP address of the device.  You can identify if via the MAC address on the table (and sticker the 3220)
May 28, 2008 | EnGenius EOC-3220 (EOC3220)
192.168.1.1??????
Hi john - the address 192.168.1.1 is the default address of your router. Your pc that you're using for setup is supposed to be set to 192.168.1.10. with subnet mask 255.255.255.0 . Are you having problems getting in to your router? Do not enter anything for the default user and password. Let me know what problems your having. Thanks.
Jeff
May 17, 2008 | EnGenius EOC-3220 (EOC3220)
EOC-3220+ flash reset probs
Hi..
I had that problem too.. I scan the radio IP with Dude, software that come free for mikrotik.. and I got 192.168.1.245 for my radio. since that day I know that 3220 will go to that IP after flash reset. the mode will be Ap only, if you change to AP on operational mode than it will go to the standart Ip either 192.168.1.1 or 192.168.1.2
Hope this will help
Apr 02, 2008 | EnGenius EOC-3220 (EOC3220)
Voyager A210 Laptop shows when connected to wifi "Limited or no connectivity"although others are connected on same router at the time. I have removed wifi program and reinstalled No difference
This is just a try. Find out the Default Gateway on the other computers. If they are using a static IP then you need to get on. At someone else's computer click Start and Run and enter Cmd and click OK.
Now type in ipconfig /all. Look for IP Address, Subnet Mask, Default Gateway and DNS Servers. Write it all down. Then find an available IP address by using the Ping command.
In the same Window, type in ping and the IP Address of the computer you are at. That's just to show you what it looks like when you find an IP already taken. You'll see "reply from..." with the address you just pinged. Now ping again but change the last octal in the IP (the last number) in the IP address to something under 256. And ping again. Do this until you get a message "request timed out". You've just found an available IP.
Mar 27, 2008 | Computers & Internet
EnGenius EOC-3220 (EOC3220) Logo
489 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
