Question about JVC Televison & Video
I do not get sound on all ch - JVC Televison & Video
  • phart14 Aug 31, 2010
    I have a JVC LT-42SL89 (Procision Full HD HDMI)
    I have sound on ever other channels
    I do get sound in AV
  • 10,594 Answers
Do you get sound in AV input like connecting dvd player or any other video source?
What is model and brand of your tv?
Let me know to diagnose possible cause of problem.
Thanks.
Posted on Aug 30, 2010
  • Shahid Electronics
    Shahid Electronics Aug 31, 2010
    OK, you have sound in dvd playback but no sound on cable channels.
    what is connections setup of cable box with tv, is it hooked through caox wire, HDMI cable or some thing? This info will help to understand the situation.
Sound surge
Reinstall audio drivers. Clean up registry and computer.
Oct 25, 2012 | HP Compaq nc6120 Notebook
I have a kicker two ch amp and when I hook up my two 15s which ever sub I hook to the right CH flexes weird and don't sound like the one hook to the left CH
well what ampage is your amp ?? for example if its a 350 amp and you have two speakers at 200 each the sound quality will be **** in other words but if you have 1 thats 150 and 250 the less powered speaker is going to give out more sound. either that or one of the channels is broke or weak
Aug 23, 2012 | Car Audio & Video
Chevy trailblzr has about 150000 miles and just started to make a loud sound ch ch ch ch ch ch ch . Loud enough that passersby look. Went to mechanic who said it is just rus and that sound is metal and...
Metal and rust reacting??? I wouldn't let that guy work on a skate board!
If it is rust on the brake rotors causing the problem, then the rotors will probably need to be machined or replaced if it is making that much noise. They shouldn't be doing that regardless of how much rain we have - that would require a LOT of rust and it would need to be repaired! Also, are you sure it is not coming from something like a bad driveshaft U-joint or axle CV joint? If it is, it could leave you STRANDED when it comes apart. I would recommend taking it somewhere else and getting the noise properly diagnosed.
Sep 23, 2011 | 2003 Chevrolet TrailBlazer
I HAVE AN AKAI TELEVISION WITH 8 BUTTONS ON THE FRONT 1 TV/VIDEO 2 CH UP 3 MUTE 4 VOL- 5 MENU 6 VOL+ 7 CH DN 8 TIMER
The button TV/Video button is used to select operating mode of the television. If you want to watch TV programs select TV. If you want to a watch movie from a DVD player you have to select VIDEO. The The CH UP is for channel search going up and CH DN for channel search going down. The VOL- is to lower the sound while VOL+ is to increase the sound. The MUTE button is used if you want your TV to run with no sound.
Dec 11, 2010 | Akai Televison & Video
ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL...
From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
Specifications
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 100Wx2
    • 2 ch: (2 Ohm) 200Wx2
    • 1 ch: (4 Ohm) 400Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 250Wx2
    • 1 ch: (4 Ohm) 750Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Hope that helps.
Nov 08, 2010 | Pioneer PRS-X720 Car Audio Amplifier
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Aug 14, 2008 | Car Audio & Video
Ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Feb 06, 2008 | Televison & Video
Need schmatic for ep2500
check preamps small parts! maybe you have change value capacitors and resistors!
Sep 13, 2007 | Behringer EUROPOWER EP2500 Amplifier
Get to the loading screen and it freezes
Is there a memory card installed? If so, try removing it to see if the game will play without the card. You may have a corrupted save file for that game.
Jul 10, 2007 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
