Question about Muratec M2500 Fax
Hi my fax is not responding and reading this message check fax remote. how to solve this problem
    Genius:
  • 1,218 Answers
Your machine is saying that after/during the last transmission that it thought there was a problem with the remote fax machine...poor modem traing, poor line conditions... who knows....however just unplug your machine for 2 or 3 mins then plug it back in...it should reset itself.
Posted on Aug 31, 2010
I have an HP 8500A printer/scanner/fax. Everything works but the fax. I can receive but I can't fax out. I get error 348, 321 & 358.
Hello and Welcome to FixYa!
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
  2. When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
If during fax you receive the Error 321 then it is because of:-
  1. There was a communication error with the receiving fax machine due to poor telephone line conditions.
You can solve the Error 321 by the following:-
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
If during fax you receive the Error 358 then it is because of:-
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
You can solve the Error 358 by the following:-
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 05, 2011 | HP Photosmart 2710 All-In-One InkJet...
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
Hi my HP printer fax was working fine but now I am getting a 351 error message I rang the fax print test and everything seemed fine there
    1. On the product control panel, press the setup button (c01661990.gif ).
    2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
    3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OKbutton (c01335940.jpg ).
    4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
    5. If the ECM is off try turning it back On
    6. Check All these other settings
    7. Press the Setup button c01661990.gif Go to Advanced fax settings and check if the Fax speed is set to medium
          Oct 24, 2010 | HP Officejet 6500 Wireless All-in-One...
          When I connect My MTS MBLAZE shows me an error message "The remote computer did not responde for further assistance" and do not respond when I check my balance and my phone number. When i check balance for...
          When I connect My MTS MBLAZE shows me an error message "The remote computer did not responde for further assistance" and do not respond when I check my balance and my phone number. When i check balance for last time their is 4 MB(approx.)data usege remening. solve this problem please.
          Jul 28, 2010 | Computers & Internet
          My logitech 550 is not responding. It has worked
          Hi. That message means that there is a button that is stuck down on the remote.
          1. Take out the battery, push in and massage each button to ensure it is not stuck down.
          2. Put the battery back in, update the firmware,
          3. Update the remote.
          That should get the remote working again. :)
          Oct 31, 2009 | Logitech Harmony 550 Remote Advanced...
          Drum error message
          check the silver spring loaded contacts inside the drum cavity make sure they casn be pushed in and spring back out. Also clea them with a dry cotton swab
          Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
          FAX 560 Brothers displays message "Memory Full"
          Do you have faxes in memory? You may need to either erase faxes in memory or print them out.
          Printing a Fax in Memory
          If you have Fax Storage ON for remote retrieval, you can still print a fax in the
          memory when you are at your machine:
          1 Press Function/Set, 8, 4.
          2 Press Start.
          3 Press Stop.
          (See Turning On Fax Storage, page R-2.)
          Apr 04, 2009 | Brother IntelliFAX 560 Plain Paper Fax
          Hi, Remote Fax Error being displayed
          Set the DRPD in the settings to 9600 and then try send a fax ...
          Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
          Memory full
          1. Fax Storage may be set to On. When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions. The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, Fax Storage should be set to Off. Verify Fax Storage is set to Off by doing the following:
          a. Press FUNCTION, 8 (Remote Fax Opt), then 2 (Fax Storage).
          b. Check the setting. The display will read On or Off.
          c. If the setting is On, press the left or right navigation key (arrows) until the display reads Off.
          d. Press SET and then STOP/EXIT.
          e. If you have faxes stored in the memory, you will receive a message that reads Erase all fax 1. Yes 2. No. This means you have faxes saved in the memory. If you do not want to reprint the saved faxes, press 1 (Yes) and then STOP/EXIT. After pressing 1 (Yes), all fax data is erased and Fax Storage is turned off.
          Hope this helps!
          May 20, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
          Muratec M2500 Fax Logo
          282 people viewed this question
          Top Muratec Office Equipment & Supplies Experts
          Kyocera HP Expert
          CheckitRight
          CheckitRight
          Ben
          Ben
          Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
