Question about Kenmore 84052 Dryer
I have a kenmore dryer model 970-C85192-00 bought in 2006, the control board seams to be defect, it is mixt up, when i have finish with the dryer and stop it, it start again by itself and it beep beep beep all the time, i tryed to unplug it for a week to reset im but it is still the same, help, a new board cost 314.99 taxes Serge
catriver
  • 878 Answers
SOURCE: Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Posted on Jul 16, 2007
  • 62 Answers
SOURCE: Cycle signal is going crazy
check vents and venting. sounds like a controller problem and unfortunatly there are no resets for that type of problem
Posted on Jan 02, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Posted on Feb 09, 2009
  • 46 Answers
SOURCE: I need help with my Kenmore Elite electric dryer
might be a bad timer
Posted on Jun 27, 2009
localwonder
  • 6784 Answers
SOURCE: No Heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 21, 2009
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Why do I have a E15 error code on my Model # 41784092500 KENMORE Residential Dryer
The micro-controller has been reset by the watchdog timer. I think you have a defective main control board.
Aug 26, 2015 | Kenmore Dryers
Error code LE for dryer
Dear Sir:
Will be a good Idea to download your instruction manual for www. retrevo.com or www.lg.com AND see the section troubleshooting you error codes.
However this is the codes:
Cl: problem link control between main dryers control board vs control board, you must replace either
Te1: thermistor defective, you must replace the thermistor. test it
in 2011 newer models has smart diagnostic.
God bless you
May 24, 2012 | Kenmore 62602 Electric Dryer
Can you stack a kenmore washer / dryer model # 970-c84102-00 and 970-c44102-00?
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Oct 19, 2010 | Kenmore Dryers
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Need to instructions on how to stack a kenmore washing machine model #970-C42162-00 with it's dryer model #970-C82162-10
to stack you will need the stacking kit. It can be order through Sears Parts/Product Repair Service department.
Sep 23, 2009 | Washing Machines
Manuals
I thinkl you can order the manuals from www.sears.com under the parts tab enter your model # also if it is an electric dry it is 220v with a neutral leg check with the local electrian to see if the power there is phased..Hope this helps
PS::The washer and the refrig will work on the tranformers
Jan 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 84052 Dryer Logo
250 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
