Question about Canon PC-980 Color Copier
Canon pc980 dF error
I am getting the dF error on a canon pc 980 when trying to use doc feeder, there is a little arrow light that says lift
Page 62 of PS980 manual shows how to get rid of the dF error, and it worked for me just now. If you can't see any paper causing a jam, there could be a small piece of paper above the white feeding belt. 1) turn off copier, lift lid, and gently pull the feeding belt. If nothing falls out and you still get the error, 2) insert a postcard to the left of the feeding belt and wiggle vertically and horizontally. To my surprise, a small piece of paper I had copied and forgotten about emerged on top of the copier lid!
Posted on Nov 10, 2009
  • 67 Answers
YOUR DF IS VERY OLD , YOU NEED A SENSOR ADJUST ONLY A CERTIFICED TECH CAN HELP ON SITE
Posted on Jun 12, 2008
Error no page in Feeder when there are pages in feeder
Need more information. Does the doc elevator lift the paper to the pick rollers? Check the plastic lever that is attached to the upper feeder cover. Make sure the upper cover is closed properly Verify that the dark colored sensor is clean in the feeding tray
May 05, 2014 | Canon DR-9080C Path-Through Scanner
We have a Canon PC980 black and white copier. When the "on" button is pushed, the error message "EO" appears. The copier will not operate at all. HELP!!!
E0 means a fuser problem, it does not heat up properly. It could be the heat element within the fuser or the overtemp fuse may have blown.
Anyway, you should really have an technician look at it for you.
Jul 05, 2011 | Canon PC-980 Color Copier
My Canon PC980 turns on but errors out
If the diagram looks like a roller, it is saying that the Drum needs to be replaced...
Sep 18, 2009 | Canon PC-980 Color Copier
Canon PC980 ADF PROBLEM
not really familiar with this model, however, you should be able to open the cover (slightly) where the paper feeds in and you will see some rubber rollers (likely top and bottom), try cleaning these with a rag dampened with some alcohol (preferably), or water, and turning gently (do not force). If you use water, dry them afterward
Feb 13, 2009 | Canon PC-980 Color Copier
CANON 4050 XEROX MACHINE
my xerox machine canon 4050 shown an eroor(E020)...we cant able to take copier
Oct 16, 2008 | Canon NP 6050 Copier
Brother DCP8020D Document Feeder
Clean rubber rollers with metho, run a page by hand of laminate or stiff card threw the doc feeder. Stick it where the paper comes out of DF and ensure path is clear.
Push down on left side or tape down little black switch (rear left corner near glass)while trying to use df to confirm hinge aint the issue
If it is the rollers it should feed when paper is "helped a little" with hand at feed time
Ensure prints ok when using glass instead of df to know it is df problem
Cheers
Apr 28, 2008 | Brother DCP-8020D All-In-One Laser Printer
Canon pc980
turn power off and then on it
Jan 04, 2008 | Canon PC-980 Color Copier
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
Canon PC-980 Color Copier Logo
245 people viewed this question
old marine
old marine
