Question about Fuji FinePix F20 Digital Camera
Lines in my pictures
I don't know what I could have done but all my pictures are coming out (on the screen and printing) with horizontal lines through the pictures. when I look at my screen it appears to be moving a little with the lines in the picture. Is there some setting I might have accidently hit? My camera works perfectly fine other then this. How can I fix it?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey Raquel Marie,
This is usually a sign of a failed sensor. I would have it looked at by an authorized service technician, and get a quote on how much it would cost to get fixed. If the camera is still under manufacturers warranty the repair would most likely be free, and the camera could possibly be replaced.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 08, 2008
Just tried to turn the tv on again, it doesnt show anything now,
Hi Zan,
May I know the exact model number of your unit, it is printed at the rear cover, receipt, and on the manual so that I can accurately diagnose the caused of the symptoms.
You have mentioned also that there's a horizontal line on the screen and after a few minutes then screen turns to black, may I know if there's a picture or just a horizontal line only?
Nov 22, 2011 | Hitachi Televison & Video
We replaced the transformer for our RCA F27650. It was sparking and now it is not, but now the screen won't turn on. It is just black. We hookd all the wires up like they were. we can hear sound, but...
Hello
Along with the flyback transofrmer, its horizontal output transistor also must be replaced. I don't know whether you have replaced it or not. If not, replace it too. It can be located very near to the flyback transformer, a three terminal component, black in colour, usually screwed to a metal heatsink. Then switch on the TV and measure the video output voltage at the video output card pluged directly to the picture tube neck. The collector of the video aoutput transistors must come around 145VDC. If it also is there, advance the screen control on the flyback transformer to get a raster. If that voltage is not there, it means that the flyback transformer is not working, and horizontal oscillator stage should be checked for oscillation, check the lined drive transformer for its primary winding open, Check the entire horizontal oscillator section. The collector point of the line drive transistor, the transistor that drives the line drive transformer, a small transformer soldered diretly to the printed circuit board; should be checked with frequency meter. The frequency at that point should come around 15525HZ approx: OK.
Mar 19, 2011 | RCA F27650 27" TV
The pictures have horizontal lines through them. The veiw screen is fine. When you review or save them to the computer they show up whiter and with lines. Thanks ahead for any help.
If this doesn't apear on the print pictures taken directly from the SD card. It has something to do with the settings for the picture transferre on your computer.
Try and reset/adjust the settings within the transferre programe. I cannot tell you the eact steps for that since it will depend on the programe you're using. But it can usually be done right before transferring pics to the computer.
If helpful pls. recommend/rate me and or give me a review. TXS
Dec 03, 2009 | Kodak EasyShare Z612 Digital Camera
Printing black horizontal lines below text/on top of pictures
Check the waste recepticle under where the ink cartridges rest in the home position. Over time, ink sprayed into this cup during cleaning cycles builds up to form a small mountain of congealed ink. If this gets too high, it makes contact with the printhead and drags ink across all your prints. If there is a ***** of ink present, scoop it out with a spoon or a popsicle stick.
Dont get it on you, its messy...
Jun 22, 2009 | Dell 924 All-in-One InkJet Printer
PIXMA iP90, all the pictures come out really faded..new ink,
I've cleaned it every which way..but still all the pictures print out really realled faded with slight lines horizontally runnung across.
Mar 01, 2009 | Canon PIXMA iP90 Mobile Printer
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
Black screen with sound only no picture.
I have same problem,it appears to be the flyback
xfr.
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Fuji FinePix F20 Digital Camera Logo
46 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
