Question about Lanier Office Equipment & Supplies
Color Regist. Error Lanier LP020c Printer - Lanier Office Equipment & Supplies
SOURCE: won't turn on....
Have you recently replaced the colour PCU? It may not be seated properly, otherwise there is likely a problem with it, and it's not turning (ie: a broken gear). It could also be the PCU drive motor, or control board. Sounds like you may need a tech to get to the root cause unless you have a spare PCU to try?? This also explains the colour registration problem.
Posted on Feb 24, 2009
vpaaf
  • 115 Answers
SOURCE: My printer is not printing at all. The following
Please press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust. If after completing the procedure the error persists, please contact your service representative for support.
icalled the comapny for you and this is what they said for your machne. Please give me good feedback on fixya
Posted on Oct 09, 2009
  • 6 Answers
SOURCE: Our printer has an error, the message reads Color Regist Error
Clean printer heads and take to pieces to see if anything stuck
Posted on Nov 18, 2009
pineworks
  • 4041 Answers
SOURCE: on the printer window, it says: Color Regist Error
Hi there
I beleave it is to perform the manual color registration adjustment.
Press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust.
But you may have to do this manully adjust all till get right,
Sorry cant help you any more than this.
All the best Pineworks
Posted on Feb 09, 2010
Testimonial: "This helped the color on pages but i am still getting the error. I have done it several times."
caroldon
  • 17130 Answers
SOURCE: I have a lanier
Remove your printer from the PC and uninstall the printer software. make sure there is no other conflicting softwares in the pc specially recently downloaded programs. If so uninstall them too. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Now make a test to see if the PC commands the printer. If there is no response, check the head assembly/ ink carriage to be struck or out of alignment. Check for possible realignment of any of these mechanical problems., jammed roller or head drive
If the catridges were removed make sure they are in place . If you are removing them make sure that the printer is shut off .
If none work it can also be an error inthe main board. Need to swap one to confirm
Posted on Sep 17, 2010
On the printer window, it says: Color Regist Error
Hi there
Feb 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Nov 18, 2009 | Ricoh Aficio CL2000N Laser Printer
Oct 09, 2009 | Ricoh Aficio CL3500N Laser Printer
Lanier LP020c laser colour printer horizontal lines
as if the cartridge is new.and colour is printing fine.then its not faulty cartridge or faulty printer.and yes you are absolutely right that it needs proper servicing.in the printer there are lens one lens is for colour and one lens is for black.if there is dust on the lens controlling black you will get lines and patches in black prinouts.but yes if the drum is got lines on it.that it will give same lines in the printouts.also you can get the drun serviced first before getting the printer serviced.a local printer repair shop does this drum servicing.also there comes a liquid to clean drum.you can get it from printer parts store.if want to do manually.but the shop will get it checked after serving in there printer.so it will be confirmed that is it drum or faulty /dusty lens in the printer. ----------- this will help.thanks.
Sep 20, 2009 | Lanier UNKNOWN
Printer won't print
The PCU is behind the right door, remove the waste toner and its the one on the left.
-Carl
May 27, 2009 | Lanier 5235 Printer
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
Colors aren't blending
We have a problem,after the calibration on the begin the printer gives an error: "Color regist. error",but the toners are full ! How to resolve?? Thanks in advance.
Mar 05, 2009 | Ricoh Aficio CL2000 Laser Printer
Ricoh service mode to reset
This is the solution from Ricoh website:
I'm told this works as well...
On the main board put dip switch 101-1 on and then off and then enter 97 and press the aps key. Then power cycle the printer.
Jul 09, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
103 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
