Question about Panasonic PT-47WX53 47" Rear Projection HDTV
My Panosonic TV Model# PT-47WX42F will not turn on. It clicks like it wants to turn on but does not. The power light is flashing 5 times
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
5 blinks is error code for short on 140 volt line inside the set; it usually means the Horz output transistor is shorted. If you have a ohm meter (used for checking fuses etc) there is a simple test to see if this is the problem.
Also associated with this is a bad capacitor near it (Location for the Transistor is C509 and the transistor should be location Q551)
Location numbers are printed on top of board near part; both parts are on (as seen from back) far right board near the large black part with big red wire coming out of the top.
Transistor is just to the left of it and cap forward about 3 inches.
If this information told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 30, 2010
  • chicki1017 Nov 04, 2010
    so i'm still confused about how to fix this problem. My tv is doing the blinking 5 times. can you explain a little more simple??
What lamp part number goes into a Panasonic PT-47wx42f rear proj tv
the set does not use lamp--it has 3 picture tubes that rarely fail.
If set does not work does power light come on and blink a specific number of blinks? 3 blinks or 5 blinks repeated are most common ones.
Aug 30, 2012 | Panasonic Televison & Video
42 " panosonic plasma model th-42px6ou keeps
There is an energy save setting on your controls. Turn that off if you don't want tv to keep turning off while you are changing inputs. Hope this helps.
Oct 16, 2011 | Panasonic TH-42PD50U 42 in. Plasma EDTV
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-51HX43G no power, red light flashes
I have a Panasonic PT53TW53G projection tv that had the same problem for power .A terrific person gave us wonderful advice and it fixed our tv! We were told to replace the IC conversion amplifiers. On our model they are STK392-110 (your's may be different). We ordered the parts from www.electronix.com and they were only $12. for the two parts. We also had to purchase a soldering iron and de-soldering vac for removal/replacement of parts. Good Luck!
Feb 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pt-47wx42f service manual
No power? as in zip, nada nothing?  Or... you turn the TV on and then it shut's off three seconds later and you get a blinking red light next to your power button?  Let a brutha know.
Oh yea... good luck on the service manual.
Sep 29, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
554 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
