Question about Braun Health & Beauty
Braun Pocketgo 570 and Series 3 340 I have bought another Pocket go razor as the cover kept fouling the foil and damaged it its a bad design as the next one does the same I feek like returning them as they are useless and also the Series 3 its cumbersome and does not give me a clean shave and Ive had Braun razors for 50 years Id return them all if you will agree thats my view Ill leave it with you John Cowling
SOURCE: No close shaves
I've replace the cutting surfaces and the thing just won't cut.
Posted on Sep 02, 2008
  • 10 Answers
SOURCE: The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Posted on Aug 27, 2009
Cytherian
  • 109 Answers
SOURCE: Head (foil and blades) used to last 10-12 months.
Six weeks? That's very peculiar. Are you certain that they are seated properly on the shaver? If there's a problem with the head and they're not fitting into place slightly off, they can end up wearing out faster.
If you've used your shaver for a number of years, your best bet is to probably step up to a newer model Braun shaver. The 7000 series was OK, but the 8000 series is much better. You can still pick up new old stock ones off "that auction site". They shave not much differently from the new 9000 series (Pulsonic). Good luck!
Posted on Oct 22, 2009
brector3
  • 1610 Answers
SOURCE: My Series 7 790cc razor became really loud after a
Your shaver came with a 2 year manufacturer warranty. Follow the warranty istructions in the user manual that came with the shaver or call Braun at 1-800-272-8611
Posted on May 25, 2010
brector3
  • 1610 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
How to fix a Braun series 7 razor that will not charge in cleaning stand
Try plugging the cord directly into the shaver. If it charges this way, your clean and charge unit is bad. A replacement can be ordered from the link below
http://shaveroutlet.com/braun-pulsonic-clean-charge-base.html
May 27, 2014 | Braun 7000 Series Foil and Cutterblock
Looking for a foil replacement for a 370 Braun Travel shaver
Braun has made two different travel shavers with the model number 370. They do not use the same foils. The foil for the older version has been discontinued by Braun and is no longer available. The foil for the newer version can be found at shaveroutlet.com. See link below.
Read the information there carefully to make sure it i for your version of model 370
http://shaveroutlet.com/shaver-replacement-parts/braun-5609-370-575-pocketgo-foil-and-frame.html
Sep 24, 2011 | Health & Beauty
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
When razor is plugged in for charging the whole razor and cord get really hot! What is going on? It is a 4700 Series razor but it says For use only with Braun Series 549 class 2 power units. Do I need to...
After reviewing your Problem , My think says , its a Machine Problem... or may be its a Heat Problem , the Reason of Heating is that , the blade of machine is not installed Correctly , so Blur your Machine , clean it all ,then it will okey.
Jul 24, 2011 | Braun 7000 Series Foil and Cutterblock
Bought a Braun series 3 razor (#340 wet and dry). It hardly shaves the whiskers but it really messes my skin up. ( I was using a Norelco which did a pretty good job) I think there is something wrong...
You should be able to run your finger over the foil mesh on the Braun shaver to feel if there are any rough spots causing the problem you describe. If there is damage you may also be able to see it.
It could also be that the Braun shaver simply does not agree with your skin type. There are many people who are sensitive to different kinds of shaving methods. Foil shavers like Braun may not be the type of shaver for you
Apr 04, 2017 | Braun Syncro 7680 Electric Shaver
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
May 27, 2009 | Braun Syncro 7526 Electric Shaver
Health & Beauty Logo
132 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
