Question about Dishwashers
I have an LG dishwasher LD2120WH and the waste water pipe has split right where ti endered the machine. Can I remove that little white 'plug' and re-connect the pipe or do I have to buy a completely new one? Can you assist me. Also the wheels on the trays dont last and I would need some of those too.
  • 213 Answers
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Posted on Nov 20, 2007
  • 55 Answers
SOURCE: hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Posted on Feb 15, 2008
  • 677 Answers
SOURCE: new dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
Master_Tech
  • 770 Answers
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
Code troubleshooting
White knight dishwasher flashing red light and. Won't. Empty .
could be something in drain pump need to bail the water out of dishwasher best way is a small scoop take filter out and you can get to the lowest point of sump. Take water out and use sponge for the dregs . Un plug appliance and turn water off remove inlet hose and waste pipe. Lay the appliance on its back and remove the base of the appliance you will then see the drain pump remove 3 screw and gently remove pump head and remove object but watch finger if it's a shard of glass .
Jul 15, 2014 | White Knight Press DW1260WA 600 mm White...
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
Want to take water hose off from back of the machine so I can feed it down the holes in the cupboard then put it back on can this be done easly or do I have to cut a big hole in the cupboard. cheers
Hi there Larry which hose are you refering to the inlet or the waste. You can take the inlet hose of very easily, However the waste pipe is conected to the waste pump inside the machine. If this is the pipe you wish to remove I would drill a bigger hole in the cupboard. let me know if this helps at all. Regards Gary.
Jul 02, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Machine just started leaving dirty water in bottom of machine. cleaned filters,had machine apart,removed and cleaned waste pipe. pump runs and impeller feels ok.only time i could get any water to drain...
Check that the pump is clean and not loose. Make sure pump, impeller, and waste pipe are in alignment with each other and are clean. If it works when you shake the pipe, then there is still a clog inside or the pipes aren't aligned correctly and something is hanging up.
Dec 31, 2010 | Dishwashers
Door won't latch on lg model LD2120wh
je cherche la télécommande de LG DR-4912V
Dec 24, 2009 | LG Dishwashers
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
How do i change the waste pipe on a Siemens SE25235 GB dishwashe?
yes. the side panel needs removing to get access to the fill/water matrix. to do this, you need to remove 2 torx 15 sized screws underneath the white seal of the side panel. make sure you have unplugged the dishwasher and disconnected its water supply. once you have access to the water matrix, place a towel or similar absorbant material underneath where all the pipes connect to the matrix (near the back) to prevent any spillages. the waste pipe is the same colour and texture right up to the connection on the matrix and is (i believe) the furthest from the door of the dishwasher. disconnecting the hose shouldn't be too difficult.
Jan 06, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
Whirlpool awm 337 does not complete a wash cycle
There is either something stuck in the water pump (rogue sock) - front of machine - bottom right, open the flap, remove the plug and check (p.s. it will drop lots of water).
OR, underneath the machine - where the exit pipe from the drum, you will see a split ring holding on the rubber waste pipe. Behind that is a ping pong ball and rubber seal. Socks and the like do collect here.
It's happened about 6 times to me, have got used to fixing it.
Aug 11, 2008 | Whirlpool Washing Machines
BOSCH SMS4472GB/20 DISHWASHER water leaking from vent/overflow hole in plastic next to flot on side of machine on third fill up
Remove the side and top panels of the machine.
On the left hand side you will see a clear plastic panel full of tubes and small tanks. This is the metering tank. At the bottom left of this unit, is a black pipe held on with a clip. There will almost definately be a blockage between this point and the sump. You can either buy and fit a new pipe or do what I did with mine, which was to remove it and clean it with hot water and a bottle brush. Seems to work like new again now.
You'll have to get the machine onto it's right side to remove the lower end of the black pipe from the sump. I drained as much excess water as possible out of the machine by sitting it on bricks, tilting it to the left and catching the water in a dish as it came out of the float hole. Some will also come out of the funny plastic tube which runs across the top of the machine - I carefully removed this first and caught this water in a pan.
Drain the waste pipe and disconnect the water supply.
Replace the right side casing on to protect the feed to the upper spray unit and put the machine on it's right hand side. Once the machine is on its right hand side, fin the water inlet valve and carefully remove its bracket from the chasis of the machine. You will need cross head and a torx screwdrivers - one for each screw. Once this is loosened, push some of the water supply pipe into the machine so you can move the bracket to the right a little to gaine access to the waste pipe. Remove this by removing the two gold coloured screws. This should now give you easy access to the sump end of the black pipe which lead from the metering tank. Remove this and clean it out. Pop all the parts back, stand you machine upright. Reconnect the watre supply and the waste and give it a rinse cycle to test - number 1 on the dial.
Hope this helps. My apologies if any of the take apart is not completely accurate - I don't want to turn my machine over again to check!
Mark
Jul 07, 2008 | Dishwashers
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
