Question about Pride New Mobility Victory XL 4 Wheel Scooter
My scooter keeps stopping after short journys
  • spacerook Feb 13, 2011
    Do you notice if it cuts out when turning, going over a bump, or at a certain speed?
    You may have to analyze the problem. Each of these has a different solution.
Trouble with new batteries losing charge. I also purchased a new charger. It will run for awhile a couple of weeks then it will just keep losing power and just stop.
Number 1, always charge after every use. You can check if the charger is charging quickly, by turning on the scooter and watching the gauge when you plug the charger in. The gauge should climb up if it does not move then charger is not working. Make sure the charger is plugged into an outlet that is not shut off with a light switch!
Check out my Trouble-Shooting guide at Scooter Doctor App
Jul 31, 2015 | Mega Motion Elite 8
2012 vitara emmission. light on and vehicle is missing
get the OBD codes read as will point to the sensor/switch causing the issue, might just need a good long run at a highish speed to burn off any deposits , what is the usual usage of the vehicle , short journies stop and start ? if so i'd get a fuel addative that covers the catalytic convertor/or if diesel get a diesel addative, and follow the instructions , I know this is 2 answers but go with the OBD codes first and if says o2 sensor try the fuel addative before replacing parts,good luck
Nov 21, 2014 | 2012 Suzuki Grand Vitara Base 4dr SUV 2.4L...
Hi moves foeward & reverse approx 6 feet stops dead ?
It can be any number of things.
1. Batteries are bad. Just because they are new, does not make them good or batteries you placed in the scooter are a lower (a.h.) than what is recommended by manufacturer.
2. short in the front/rear harness.
3. short in console.
4. park brake issue.
5. Thermal rollback.
It is an issue that a Technician should look at.
Aug 29, 2014 | Pride Mobility Hurricane Personal Mobility...
Scooter shorts out while runing
possible throttle pot failure.
Aug 23, 2014 | Health & Beauty
3.1 grand cherokee jeep 2001 td ltd boiling over chandged rad ,stat ,pump seems ok any ideas .ok on tickover with pressure cap on or of but when driving for about 30min car boils over and water light comes...
Check out the fan, maybe is not working, about 1 year ago same happened to me, changed many parts but keep getting hot and finally found that the fan had a short circuit and sometimes didnt work.
There is a connector between the fan motor and the fuse box eliminate the connector instead directly join wire to wire
Oct 17, 2010 | 2001 Jeep Grand Cherokee
When I stop the scooter after travelling a short
Hi. Yes, most, but not all machines have a "sleep" mode. More for safety than any other reason. Neil .
Oct 31, 2009 | Electric Strider Maxi 4 Wheel Mobility...
My battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Oct 29, 2009 | ElectroVoice EV Rider FTCA020 Caddy Fold N...
Hi it keeps stopping,leave it 5 mins and it will go again for a short while.
sounds like the brushes could be worn out,
Connection form the batteries to the motor controller then check the M+ M- leads from the controller to the motor
Could be the controller breaking down
Batteries are okay ? or simply the speed pot is worn,
when it stops , move the throttle lever upwards, does it start to go again, if so a new speed pot is required.
Regards
Gewiz.
Oct 05, 2009 | RTO 4 wheel Heavy Duty Mobility Electric...
Maxi strider scooter
Hi
Are you sure it 's the cable ? and not the wig wam or throttle speed pot that you operate with your thrumbs.
Regards
GeWiz.
May 03, 2009 | Electric Strider Maxi 4 Wheel Mobility...
1991 Sonoma won't start and backfires when turning over
chech plugs and wires replace first. how many miles since a tune-up?
Mar 23, 2009 | 1991 GMC Sonoma
Pride New Mobility Victory XL 4 Wheel Scooter Logo
265 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
