Question about Acer Aspire 4315 Notebook
There seems to be a mechanical problem with left click button. How do i repair it please.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 30 Answers
First open the keypad n clean its button with the help of brush,,,if the problem still continues then you are adviced to change yor key pad
Posted on Aug 30, 2010
Toyota corolla problems
I'm no mechanic but sounds like either a wheel bearing is going or gone, or could be your universal joint going on that side. not something to let go if it is either, as it could break and drop the car to the ground. please have it checked...soon!
May 12, 2014 | 1999 Toyota Corolla
My dell inspiron laptop's left click button isn't working as well as it use to, i think it maybe worn down, is there anyway i could get it replaced, and if so, where?
Simple solution with less cost is please use the external USB mouse.(Small size also avaible in market.) You are not mentioned the location where you are, Please locate the nearest Laptop service center for repair/replacement.
Try once with installing the Touch pad drivers.. .
Jun 28, 2011 | Dell Inspiron 1750 Laptop
On touch pad, the left and right click below the pad, for the mouse, the left button doesn't click anymore?
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Jun 09, 2011 | HP G70-460US Notebook
The Nightshot Plus button was left on and now I cannot change the date when I turn on the camera. I seem to be able to record but I cannot playback what was recorded - none of the functions seem to work.
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 19, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
Left click button on samsungR519 laptop seems to be 'stuck on' so is clicking on everything you rollover with cursor
Does this issue persist even after rebooting? Is the same true when using a usb mouse?
Answers to these question will assist in resolving your issue at hand.
Depending on the button type there is usual a mechanism that sometimes fails not allowing the button come back up. This will require a part replacement and work will need to be done by a professional Laptop Tech
My I recommend Live-Tech Laptop Mail In Services
Live-Tech 1-888-361-8511
Thanks Frank.
May 24, 2010 | Samsung R610-64G Laptop
My System Mechanic Professional not is too good: "the component"iolosystenservice" is required for System Mechanic Professional to operate properly and could not be started please let me know some...
The "the component IoloSystemService" Error message shows up due improper installation of the System Mechanic Pro. Some of the Iolo dependencies failed to get activated and that is the problem.
Now the only solution to fix it is to follow a thorough uninstallation of the System Mechanic Pro.
For WinXP, you can uninstall it from the "Add or Remove Programs".
Next, once its unistalled do not RESTART the PC.
Now, go to the Registry (press "windows" + R to open the run command and type "regedit").
OR
Click the Windows start button and select RUN. Type REGEDIT on the openfield.
On the left-hand side, expand HKEY_CURRENT_USER by clicking the + symbol next to the entry.
Expand Software.
Expand the iolo folder.
Navigate to the System Mechanic Professional folder.
Right-click on the System Mechanic Professional folder and select Delete.
Click Yes to confirm the deletion.
On the left-hand side, expand HKEY_LOCAL_MACHINE by clicking the + symbol next to the entry.
Expand Software.
Close the Registry Editor.
Click Start>My Computer and then navigate to your Local Disk (usually the C: drive) then Program Files\iolo\System Mechanic Professional.
Click Yes to confirm.
May 19, 2010 | Iolo Technologies System Mechanic: Windows
Two buttons beneath touchpad are not working
You should clean the button by opening the cover, realign it, and check if the button touches to the board.
Nov 12, 2009 | Sony VAIO Notebook PC VGN-NS235J/W
Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Right button doesn't work; single click with left button
You can probably repair this yourself if you are technically inclined and careful.
There is a tutorial here showing how to disassemble the mouse: http://www.vk2k.com/Logitech-MX1000-Battery/
The microswitches for the buttons can be opened if you are very careful, and then you'll have to clean the contacts. Regular rubbing alcohol should work fine. Be careful not to lose any parts when opening the switch.
If the switch contacts have corroded, you may have to replace the contacts or the entire switch. You may be able to take a similar switch from another mouse (many manufacturers use similar switches). SWometimes there are MX1000 or similar logitech nonfunctioning mice being sold on eBay for parts.
Good luck
Mar 03, 2009 | Logitech MX1000 Laser Cordless...
My mouse buttons on laptop are very loose
It looks like you have broken plastic grove that holds the button to place...and this is giving you the clicking sound...
if you don't to use an external mouse....you will need to take it to repair center ...if you think you are capable of opening the top cover of you notebook without problem....let me know...
Cheers
Nov 13, 2008 | Toshiba Satellite A100-S8111TD Notebook
Acer Aspire 4315 Notebook Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
