Question about Dishwashers
My whirlpool dishwasher is showing a F7 error code what does this mean ?
  • Anonymous Mar 22, 2014
    F7 error code any ideas
    Problem Solver:
  • 16 Answers
F7 error codes on whirlpool normally mean you have a bad control board..
Posted on May 09, 2008
What does the F7 code mean for my whirlpool dishwasher ADG6230
F7 or 7 times flashing
Flow meter failure
Symptom:
Water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Reason:
  • Water tap closed during water inlet
  • Water inlet hose blocked
  • Water inlet valve (WV1) defective (mesure resistor ca 3,5 kOhm)
  • Flow meter (FM) sends too few / much pulses (less than 10 imp. in 10 seconds). Flow meter counts wrong (or the sump is full in less than 30 second).
Causation: Hose felt down and slipped the disc of the valve. The effect is a displacment of the valve tapped.
  • Aquastop defective
  • Flow meter (FM) defective
Dado
Feb 17, 2015 | Whirlpool Dishwashers
F7 is showing and every tme we reset it starts off then returns to F7
Generally depending on the brand the F7 error code is a FLOW METER problem. Is your dishwasherone of these brands
whirlpool
kenmore
kitchenaid
roper
estate
kirkland (costco)
is it from IKEA
If it is a whirlpool brand its very likely the flow meter that is the problem. This is what the flow meter looks like if it is one of the above brands
it is on the left side wall inside the tub and its where the water enters the tub, to replace it ya need to pull the dishwasher out of the cabinet
GENE
Aug 27, 2011 | Dishwashers
What does erroe f7 mean?
Hi
This error indicates a fault with the water flow meter. F7 means inlet flow meter malfunction
Remove the left panel and check the flow meter, try to unplug it and plug it again.
If not OK, change the part, If you have checked the sump filter at the bottom of the dishwasher, then close the door and turn on the power. Then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | Whirlpool Dishwashers
Code f7 appearing on whirlpool dishwasher adp 6940/5
f7 means a water flow meter problem. Either your dishwasher is not getting proper water pressure, or the flow meter is bad. Check to make sure you have good water pressure to the dishwasher, and then check that your water is coming in at a good flow rate. If both of these are ok, then replace the flow meter. If your house water pressure to the dishwasher is good, but your water flow coming into the dishwasher is slow, then your dishwasher water valve is probably plugged. Some valves you can take apart and clean out, and some you will need to replace. Good Luck, Appliance Specialists
Dec 08, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwasher does not wash simply beeps continously and wont start the rinse cycle with green flashing pre rinse light. Have tried turning off at power and have checked all connecting pipes. Have emptied...
If your dishwasher is a whirlpool or IKEA then maybe the answer given by emmanuelr in "Whirlpool dishwasher ADP5962 F7 error code" may do the trick. It certainly worked for me. Bit technical but if you are happy taking the sidepanels off the thing then the fix may be easy.
Apr 06, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
emmanuelr is spot on with this advice. The dishwasherr had been idle for a few months so as advised disconnected and reconnected the connection to the water flow meter and job done. My friend you are a scholar and a gentleman thank you so much. You are not an apprentice to me.
Dec 03, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
F7 error
Raise your water supply temerature. Next open door and within 3 seconds hit hi-temp scrub, then energy saver. Do this again. Close door and latch, then push reset button.
May 22, 2007 | Whirlpool 24 in. ADG7952 Built-in...
Dishwashers Logo
1,352 people viewed this question
Top Dishwashers Experts
