Heating & Cooling Logo
Anonymous Posted on Aug 30, 2010
Hi, I replaced the heat sensor for pilot light with an after market from Big R and now when I turn the dayton unit on, it makes a sonic boom before it lights... not a good thing right? but it does blow heat and runs good after that. So my question is does it have to have a sensor unit just for dayton? Or is there another problem like heat exchange cracked ? Thanks, Phil
  • Anonymous Aug 30, 2010
    Thank you, I'll try that and I'll let you know. Phil
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on Aug 31, 2010
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3072211
Points
30576
I would inspect the regulator. It seems it doesn't let the flow of gas seep out slowly when it ignites
Dan Webster
Level 3:
  • Dayton Master 8,221 Answers
  • Posted on Aug 30, 2010
Dan Webster
Dayton Master
Level 3:
Answers
8221
Questions
5
Helped
2379095
Points
25840
You probably have rusted burners. Remove them and wire brush them . Look for a split in one or blockage. Blow em out with shop air. Gas is pooling up before ignition. Rusted burners Seen it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
How to light a pilot light and find it on a suspended Dayton 3e837 unit?
If this heater has a standing pilot locate the gas valve on the lower back of the heater. Follow the 1/4'' aluminum tubing into the burner compartment. At the end will be the pilot assembly. Usually there is some type of access door or the bottom panel on the heater comes off or swings out of the way
Dayton gas furnace model 3e385 works and lights but as soon as fan comes on the unit shuts off and lights again wondering what was wrong
Check heat exchanger for cracks or holes which will cause the fan to blow out the flames. The flame sensor on the pilot or burners has to be in constant contact with flame to operate normally. If the flame is put out by a cracked exchanger the exchanger or furnace needs to be replaced.
Dayton3e368a pilot lights but burners do not come on. Heat rod was replaced last year. Heater is in a greenhouse
Most heaters has a pilot proving sensor of one type or another, it will be in direct contact with the pilot flame to prove that the pilot is lit and then will allow for the main gas to the burners to open. If the proving device has failed then it needs replaced.
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Have a Dayton 600,000 BTU and it has a delayed ignition. It fills up with fuel before it lights. When it does light there is a big cloud of smoke. Any suggestions on why it does this.
For that big of unit I would add at least two more pilot lights. Try to position them so they are equal distance from existing pilot.You can buy pilot light assemblies,pilot light tubing,andfitting at most H.V.A.C. supply centers. Hope this helps you. Thanks
1helpful
Pilot light goes out when turning on the thermostat
Check your thermocoupling to make sure that it is sensing flame. You can tell if it is good or bad by the white on the tip of the flame sensor. The other problem would be a blocked or closed flue pipe. Make sure that the cap is not smashed down on the pipe on your roof
Dayton 3e239e looking for operation manual
Normally you turn the gas valve to the pilot position, light the pilot, hold down the gas valve knob for 30-40 seconds and release. If the pilot will not stay lit replace the thermocouple. These are available ay Home Depot.
Ray
1helpful
2answers
Dayton Infrared natural gas heater ignition/flame sensor
Yes, the flame sensor is part of the intermittent pilot assembly. Check the following: make sure all grounding wires are secure and no corrosion is built up on them. Clean or replace the pilot assembly, also clean out the orifice with a very small drill. Make sure the sensor is in the flame and make sure the pilot tube is not leaking gas reducing the gas pressure at the pilot.
If it continues, you will have to replace the ignition control.
Top Dayton Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
