Question about Sony STR-V444ES Receiver
Sony Receiver STR-V444ES and Blueray
Uable to get the Sony to recongize the coaxal or fiber digtal sound out of my new Panasonic 108I Blueray disk player.
    Novelist:
  • 146 Answers
You might have to go into the players setup and select the output and audio stream options. If it is set for PCM only it will not receive the Dolby or DTS signals if you selected them in the DVDs audio selection menu. There may also be a signal select in the Sony receiver to assign the digital inputs to selected units.
Hope this helps
Cheers
Posted on Jan 01, 2009
What's your problem?sony v444es 5,1 wont turn on, only clicks the relay on power board non stop
Sounds like your power transformer is bad. You might also check the power board for cracks. This model had a history of that.
Jun 21, 2012 | Sony STR-V444ES Receiver
Hi - I have a Sony V444ES receiver that I have four speakers on A (in house) and two on B (outside). I hooked up a third speaker (rock speaker) for outside use however the sound is very low compared to the...
What's a rock speaker? All you will hear with one speaker on the Rear Right output is the Rear Right channel which is typically for effects and ambience. You DO have a manual, right?
Individual speakers commonly have different responses given the same amplifier input. Where you physically place a speaker once it's electrically connected is up to you. Speakers placed outdoors might not have the sound-re-enforcement of nearby or adjacent walls as indoor speakers do so they will sound weaker.
Jul 11, 2011 | Sony STR-V444ES Receiver
Receiver str-v444es no sound on headphones or
discharge the output circuit! If you don't you will blow a 10 ohm resistor every time. I've worked on hundreds of these receivers I know. They need the output circuit soldered at the voltage driver ic's and quite possibly some capicitors replaced on the digital board. The caps mounted near the heat sinks dry up the fastest. These are nice amps. Larry's Electronics Sacramento Ca. ledstiles@hotmail.com
Apr 24, 2010 | Sony STR-V444ES Receiver
STR-V444ES just hums
Sounds like the output stage is shot.
Here are a few things to try. If there is an option in the manual to reset the unit to factory settings, try that.
If that doesn't work, disconnect all of the peripherals, and select the radio. If you get sound there, you may have a bad cable.
Beyond that I would say the amp needs repaired.
Cheeres
Jan 01, 2009 | Sony STR-V444ES Receiver
Rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
Mar 02, 2008 | Sony STR-DE625
Sony V444ES Receiver
Ours started doing this also now up to 20 min of clicking before it turns on.  My thought is that it is a bad power supply since once its on it works fine.
Aug 03, 2007 | Sony STR-V444ES Receiver
Sony STR-V444ES Receiver Logo
115 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
