Question about LG GL6000ER Air Conditioner
Non cooling after sometime of running, ac compressor stops (No ice is frozen on air filter and coils )
  • 828 Answers
If the running capacitor is bad the compressor will draw above average amperage and the overload protector will cycle the compressor off. You should take it in for service.
Posted on May 08, 2008
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
It cools great when first turned on. After so many hours of cooling it stops cooling
Have you checked up in filter area at ceiling to see if fins are frozen or frosted bad? If they are dirty, they can cause frost/ice and AC goes in to fan only until frost/ice is gone. When did unit actually get a good cleaning last? Too many registers closed or blocked can cause freeze up as well. Does this unit have ducted or non-ducted system?
Aug 18, 2013 | Dometic Rooftop RV Air Conditioner
A/c will not cool
have you removeing the filter from the front of it sometimes colecting all that dust in it can cause it send only luke warm air out also if youve had it on none stop it can sometimes freeze but then letting it sit for a couple hours to a day usually solves that
Apr 13, 2013 | Heating & Cooling
My hotel room ac is blowing cold air just not strong enough to cool entire room
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Apr 06, 2017 | Heating & Cooling
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
Ac has been running for about 12 hours but the fan didn't seem to be blowing very much air and it isn't cooling the room. I just turned it off, but the motor still seems to be running or maybe it's the...
have you been able to see if the inside unit coils are frozen since its not moving much air or if there is a restriction of air by dirty filter or insulation of the cabinet panels fallen in ?
Aug 20, 2010 | Maytag M6D24E7A Air Conditioner
I have a RUUD RCBA-3765G Coil. When my AC stopped cooling I went to the basement and opened the access panel. When I looked at the coil it was frozen completely, the insulation was frozen to the front of...
This could be caused by a low refrigerant charge or dirty filters restricting the airflow. Also it will happen if the indoor fan isn't running.
May 02, 2010 | Heating & Cooling
Ac will not cool down
first you need to determine if the furnace coil is frozen or iced up. The water around the furnace means that the water is not draining where you want it to go. This can be from a blocked drain line or a frozen coil. The fact that the system is not cooling may mean that the coil is blocked. Turn on your blower only and let the air flow warm the coil if it is frozen it will start to melt. The system is then low on charge or the air flow is blocked by a filter or bad blower
Aug 13, 2009 | Ruud UBHC Air Conditioner
Price to replace cooling coil on WeatherKing 12AJA4801
If the coil was frozen over it tells me there is a different problem. If the coil is frozen over try this. turn the circulating fan to the on position and the sir conditioning to off . Let it run this way for 1-2 hours to melt the ice and re-establish the air circulation. Then turn the a/c back to the cool mode and see how it performs.
Lower temperatures during evening and night conditions can cause coils to freeze over. Running you A/C with the fan in the on position generally takes care of this problem when you are cooling.
Jun 04, 2008 | Weather King 10AJA2501AH Air Conditioner
Non cooling
Check the indoor fins and air filter if dirty, so if its dirty cleaning is needed specially the indoor fins it should not be block with dirts6702929.jpg. But if it is clean then you need a qualified technician it may need additional gas.
Mar 09, 2008 | LG GL6000ER Air Conditioner
LG GL6000ER Air Conditioner Logo
144 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
