Constant reset/report problem
I cant close out a window without a window pop up preforming a send problem message and setting a restart. I use a verizion Broadband USB for internet access is thet causing the problem or is it a vista issue?
Most likely a problem with the laptop/windows. The error box you are getting asking about sending a report to Microsoft will only come up when a program ends abnormally. If it happens with just 1 program, it's probably that program having a problem. If every program gets that message, it's probably either a windows problem, or hardware issue.
Posted on May 08, 2008
NEC DT700 series message: SIP Server Not Found
The phone is not being routed to the SV8000 Series SIP server. You could try to reset the phone to default in case it is holding a previous setup and attempt to allow it to pick up the new settings. While the phone is searching for DHCP press Hold, transfer, *,# The display should show ADMIN Put in the password 6633222 (Admin default) You should gain access to to the phone system Press 3 then Press 3 to access factory default. Ok that and the phone will preform a memory wipe. It should then do a restart and try to pick up the settings. If you cant access Admin (Have they changed the PW?) or it doesn't work then the phone needs deleting and resetting from the SV8000 series server, the ports for Voip need passing through the firewall or your phone needs to join a VLAN. None of these things you can do if you don't have access to these systems or the knowledge to program.
Nov 23, 2012 | Lands Phones
Tip
Disable The Send Error Report, to Microsoft
Open Control Panel
Click on Preformance and Maintenance.
Click on System.
Then click on the Advanced tab
Click on the error reporting button on the bottom of the windows.
Select Disable error reporting.
Click OK
Click OK
on Apr 12, 2009 | Microsoft Windows XP Professional
When i login to my yahoo messenger then a pop up window is coming saying that--- A problem has occured dont send report and when i click on it its getting closed what to do.
it might be the connection from your ISP. just click try again, if it still persist close the window and call it up again.
Jul 01, 2010 | Yahoo Messenger
HOW DELIVERY REPORT OF TEXT MESSAGE WILL COME
Go to the phone menu, press messaging, press options, scroll down to settings and press it. Press Text Message, and you will see "Receive report", then press it to turn it on.
When Delivery report is enabled in your text message settings, each time you send a text message, a delivery report message will pop out.
Take care
Dec 22, 2009 | Nokia N70 Cellular Phone
I get a popup mesage telling me an error has acured.
Click on "start" then "Run...". In the "Open:" box type in:
msconfig
and click on "OK".
Click on the "Startup" tab and look for a line containing IDTSysTrayApp and/or sttray.exe.
Uncheck the box on that line, and click on "OK", then "Exit Without Restart".
The audio should still work - this just disables the IDT system tray icon.
Apr 05, 2009 | Microsoft Windows XP Home Edition
A problem with The Sims Pet Stories
When you had the game before, were you running a different version of Windows than you are using now? Are you using software now you didnt have before? Has the game ever worked properly? Head to the game company's website and see if there is a patch or an update for the game. It seems like a hardware to software issue. Reinstall the game, restart the computer (even if youre not told to do so), then look for a patch. If there is one, follow the instructions to install it, and restart after installing the patch. DO NOT TRY TO RUN THE GAME until all of this is done first.
Mar 24, 2009 | Computers & Internet
Canon MX 300
I cant send Fax. I also receive a message ''waiting for report''and"memory receive mode". Please Help
Sep 17, 2008 | Canon MX300 Office All-In-One Printer
(internet explorer) there's a pop-up that comes on and it say's that they are sorry for the inconvinience and any files open may be closed and it has a box with acheck mark that reads restart internet...
need to reset it ok go to control pnael then internet options then clean del out temps under genreal tab then go to far right advaced tab in ther reset exployer ok thehn go downloa d junk cleaner ccleaner.com ok great tool should be good also go to adobe.com dl latest flast player and shock ok and do windows update
Jan 23, 2008 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
