Question about Nikon Coolpix 4100 Digital Camera
Memory gone wright protected - Nikon Coolpix 4100 Digital Camera
  • 4 Answers
You may have moved the little slider on your memory card that makes the card write protected. Remove the card and slide the little switch on the left hand side.
Posted on Oct 14, 2010
Everytime i put my camrea on it says ''wright project'' how can i get it off
You declined to specify what model Olympus camera, so I'm assuming it uses SD/SDHC cards. I'm also assuming it actually says "write protect."
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 20, 2012 | Olympus Cameras
Hi, The camera shows" This memory
You didn't specify the make and model of your camera, so I'm going to assume it uses SD cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 13, 2011 | Cameras
My memory card is wright protected ,how can i unprotect it?
Take our your memory card. There should be a small tab on the upper left of the card that can be adjusted either up or down. Just adjust it in reverse of the present position to unprotect it.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Computers & Internet
Disk wright protection
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 17, 2010 | SanDisk 2GB microSD Memory Card
Write-Protection?
Put them into "my sounds" folder or into a music folder and use them from there. The ring tones are wright-protected.
Jun 22, 2010 | PNY 2GB microSD Memory Card
My memory card is write protected.how to remove it?
Some SD cards have write protect tab on the side but not all do so check for that tab. If it does not have write protect it may be you device you using it with or the memory card as a whole has gone out on you.
1. Check for write protected tab on the sides of the card
2. Check the device (try reformatting it in a card reader)
3. Replace memory stick.
Thanks and please do be considerate when leaveing feedback and ratings today, thanks
May 30, 2010 | SanDisk 1GB microSD Memory Card
I recently bought a micro mini, transfered pics from cell phone, put micro into the min adapter and into my laptop, and laptop did not see it. Tried another mini disk and the drive works...
See if the adapter has a small switch on it (for wright protect) an move it . if this not solves the problem try another adapter (ask somebody to borrow one). if it`s still not working your MicroSD may be compromised, but this is really hard to happen.
Nov 16, 2009 | PNY 2GB microSD Memory Card
My 1 GB mmc memory card was not formetting properly
your card may be crupt or virus infected
please format card and turn phone to factory settings then try the card againif not work you have to buy new card.
Oct 09, 2009 | Nokia 6680 Cellular Phone
Memory card write protect?
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!...just make sure the lock is off!
Jun 02, 2009 | SanDisk 1GB microSD Memory Card
Camera card said it is full
Does the memory card have a 'write-protect' lock on it? on an SD card this is a small plastic lever on the top right edge.
Have you tried to format the card with the camera?
Can you read and write to the card with a computer and card reader?
Does this card work in any other cameras?
Dec 11, 2008 | Kodak EasyShare C330 Digital Camera
Nikon Coolpix 4100 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
