Question about Kenmore Dryers
Kenmaore 80 dryer - doesn't work at all - the door light comes on when I oppen the door and turns off when i hit the door close switch. I
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Kenmore 80 series dryer
the door trigers a switch when you open & close the door its needs replaced as for the light replace the bulb
Aug 06, 2013 | Dryers
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Have power to dryer . but now nothing works including light when door is oppened
Bad door switch. Replace door switch and should be good to go. Hope this helps.
Feb 05, 2010 | Kenmore Dryers
I have electric series 80 kenmore, all of a sudden it wont turn on, still getting power because light is on when door is closed. turns off when door opened. hit button and nothing happens at all.
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Dec 13, 2009 | Kenmore 63942 Dryer
Kenmore 80 series Dryer: Door Light stays on and wont start
Mar 05, 2009 | Kenmore 800 7982 Dryer
The light burned out last week and now the dryer won't turn on
Some dryers that have an interior light that is controled by the door switch, check the light to see if it's burned out, if it's not your door switch may be bad, when you open the door the door switch allows the interior light to come on, when you close the door the door switch shuts the light off, a bad door switch will not allow your dryer to start.
Feb 28, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Not Working
Got it. It was the door switch. I wrote that it "could suddenly break, I guess" and that's just what happened. The switch is not in the latch; there are no wires in the door. The switch is mounted on the upper right of the door frame. There's a black plastic paddle that closing the door pushes back. Ours broke off (making it harder to see). I'll order a new part, but for now, I taped a piece of plastic to the door that reaches the broken switch.
By the way, if you are new to dryer repair, as I am, you might not know that the top deck is hinged at the back. You have to pry up the front (there are two rubber restraints) after disconnecting the lint trap shaft. The door switch is easily accessible from the top (at the right). Don't forget to turn off the power.
Nov 28, 2007 | Kenmore 63942 Dryer
Dryers Logo
24 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
