Question about EliteGroup RS482-M Motherboard
I can't switch RESET CW , LED SW, HDD SW, POWER SD to te Motherboard, it doesn't work corectly and I don't know what to do
atlasuk2007
  • 85 Answers
SOURCE: reset/power/led etc..lead connections
hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
Posted on Aug 05, 2007
Sutibun
  • 186 Answers
SOURCE: I have an
the top image is the one to follow pin 1 is at the bottom left of the pins (closest to the bottom of the case. also you do not have to use all the pins.
Posted on Dec 29, 2009
Testimonial: "YES, YES, YES !!!!! Very helpful. Thanks so much. I'm back in business again!! I LOVE IT!!!!!"
  • 979 Answers
SOURCE: i need the rightorder to put my new case wires ie
Hello james, this is the link for the motherboard manual, you will find here what you are looking for. http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=79&CategoryID=1&DetailName=Manual&MenuID=1&LanID=9
Posted on May 05, 2010
map9966
  • 2351 Answers
SOURCE: where does the HDD Led, Power SW, Reset SW, and
You'll need the manual for this MB. If you do not have it you can download it from the link provided;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Manual&MenuID=1&LanID=9
You'll also need Adobe reader to view the manual. Download Adobe here; http://www.adobe.com/products/reader/
Open to page 12 and zoom in with Adobe if needed. See pages 4 and 5 for location of, PANEL1.
Wire colors do vary from case to case. Colored wires are more often positive where white is common for negative. As you look at you're case wires you will find one color in common with most of the jumpers. This common color will be positive.
The internal speaker wire colors are red for positive and black for negative.
Main Web Page for ECS GeForce6100SM-M (1.0)
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailId=685&DetailName=Feature&MenuID=1&LanID=9
Take you're time.
Mike
Posted on May 13, 2010
clokker
  • 253 Answers
SOURCE: I cleaned my pc, and disconected the wires that
http://www.starlino.com/data/remote_pc_switch/images/front_panel_connector.gif
try this maybe it helps.
Posted on Jun 15, 2010
Motherboard User Manual For SiS965L?
SiS965L is a chipset designation, not a motherboard model number. That said, most motherboards do label the header pins for the front panel connections on the motherboard, though they are a bit small and sometimes are not adjacent to the pins themselves. The Power Switch and Reset Switch pins are not polarized, and when you determine which they are, the connector plug can be installed on them either way. The Power LED and HDD LEDs ARE polarized. The positive pin is marked with a "+" sign and the Green wore of the Power LED and the Red wire of the HDD LED must be on the "+" terminal.
Nov 09, 2015 | Computers & Internet
I have installed a new motherboard in an acer case. The power cable from the switch on the front of the case will not connect to the board. Can anyone help? Thank you
You should read the motherboard manual, for cabling:
1. Power SW
2. Reset SW
3. HDD led
4. Power led - and power led +
5. Speaker
Cabling scheme, also written on the motherboard.
If the Power SW not installed the switch on does not work.
If the Reset SW not installed the switch reset does not work
If the HDD led
not installed the hard drive light (red) is not lit
If the Power led (+/-) not installed the power light (yellow) is not lit
If the Speakers are not installed, when the computer is on the beep sound is not heard.
I hope this information helps.
Oct 15, 2011 | Computers & Internet
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
Nov 24, 2009 | Computers & Internet
Number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Apr 18, 2009 | Intel Motherboard
Foxcon Motherboard pinout
Hi bwalker24,
This is a pic of how to connect you're LED & switches.
f0649db.jpg Enjoy!
Mike
Jul 25, 2008 | Foxconn 661M03-G-6EL Motherboard
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Front Panel Switch wires
If you can see, this is the setup
Jan 25, 2007 | Gigabyte GA-7ZXE Motherboard
EliteGroup RS482-M Motherboard Logo
131 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
