Question about Vizio VW42LF 42 in. LCD HDTV
I have a vizio flat screen and the color is off.. I do not know the number settings it should be on
  • Vizio Master
  • 5,568 Answers
Check on initial settings in your menu; most makers provide a 'factory default' selection that will come pretty close.
It may also have 'Warm' and 'Cool' settings for color that provide either vivid color or less intense.
Posted on Aug 30, 2010
Best color settings for Vizio flat screen smart TV.
It will depend according to your viewing taste.
Jan 18, 2016 | Vizio Televison & Video
Vizio LCD SV420XVT1A-has a red screen when starting then red bleeding through dark
Got to go to settings to change the color of your tv screen and see if that helps
Jan 23, 2015 | Vizio Televison & Video
Could wiping our 42" Vizio TV with a towel make our color change on the TV?
if you used any cleaner with chemicals in it that would leave streaks that cannot be removed, clue to this would be with set off you should be able if that happened to see it on the screen with the set off.
Otherwise there are a lot of things that can and do go wrong--a suggestion= you can post a video question here, take a video and upload it along with the brand and model number of the set in the text part of the question and post it in Flat Panel TV sets--if you want you can in the title also mark it Attention SD tech which is my user name here--if I see it (I do not miss too many) with the video I will at least be able to see what you have and make a suggestion on this problem.
this video feature is new here on Fixya so be patient.
SD TECH
Dec 19, 2012 | Vizio 42 in. LCD TV
Can't get full screen on Vizio VA19LHDTV10T
This is either due to some incompatibility or change of format of picture. Also the color system should be same like PAL/SECAM etc.
Aug 03, 2012 | Vizio VA19LHDTV10T 19 in. LCD TV
Red coloring book picture on the vizio!
Sounds like a main board issue--set has a board that controls all info and communication inside the set===faintly possible are also if this is on only part of the screen other boards but main sounds like your problem---All the digital processing for the set including what is on the screen is found there.
It might be helpful to do some research via Google====one place I like to look for info and parts info is shopjimmy.com===if this set by model number is there they will have a list of the boards and prices also----
Also Google the model number with "problems" to see what is out there.
Jun 02, 2012 | Vizio 42 in. LCD TV
My Vizio 42 in. LCD TV has red lines or outlines on the screen. It goes in and out, but doesn't hardly go away. It happens no matter if the cable, dvd or xbox is on. I have tried messing with the settings...
would most likely be a problem with the mainboard does the menu of the tv look normal it should be blue. if the menu looks red like the video then it is most likely a bad mainboard if you were to post the model number i can find the part number for that mainboard
Jan 06, 2011 | Vizio 42 in. LCD TV
Vizio plasma Tv Model P42Hd ,Tv has gone into some sort of test pattern on screen, has a color band of several colors from left to right on screen. The colors move up and take the position of the one...
with set unplugged, hold down channel up and down on the front panel at the same time while you plug the set in. Power light will go amber like it is in the off mode and when you hit the power button the set should come up and be normal.
Dec 17, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
The brightness of my screen has gone out now the colors in the screen are not as bright. Can you help me out?
check your settings under the menu or call tech support to walk you thru it the number should be in the owners manual
Aug 01, 2010 | Vizio VO47L 47 in. LCD TV
Color on vizio 37" lcd
I would recommend a Main board replacement.
Mar 04, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VW42LF 42 in. LCD HDTV Logo
81 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
