Question about Sr Smith PoolSonix Pool Alarm
When I power on my poolsonix, the 2 led flash red and green and it beeps every 10 seconds - it does not respond to key pad or key fob. Please help
  • 640 Answers
Below is a link to the users manual for these pool alarms. They have a troubleshooting guide that should either help you correct the problem or let you know who to contact if it is something that you cant handle yourself.
http://www.backyardcitypools.com/images/srs/pool-sonix-installation-manual.pdf
Posted on Sep 02, 2010
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
I ahve a beeping sound that is coming from my garage door opener.
If you have an opener with battery backup this may help. BBU stands for 'battery back up.'
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing GREEN LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jul 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hi, my old remote key pad used to lock itself so if I bumped it in my pocket it wouldnt start. I bought a new 2 way recently but the key pad stays unlocked. How do I get it lock?
Press and hold the "f" for 8 seconds to access the remote programming features. The remote will emit one long beep and the LEDs will illuminate. Press the unlock button to access the remote programming features. Two transmit LEDs will flashes and two beeps indicate the remote programming features are accessed. Press the lock button on the remote( LED on indicates auto locking on, LED off indicates auto locking off). Press and release "f" button to exit programming.
Apr 12, 2011 | 872 Responder LE keyless entry security...
The main unit beeps every 30 seconds
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing green LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Lift masters battery keeps bleeping every 5 seconds,does this means my battery needs replacing.
Jan 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
The battery backup beeps and the service light is on. The battery tests good with a volt meter
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Opener beeps
Nov 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Sep 23, 2010 | Deadbolt Locks & Locksmithing
Lotus elise 2005 fob and key does not work
Re-synchronize the FOB if the problem is with just one key.
1. Hold down both buttons simultaneously until the fob LED goes out. (10 seconds)
2. Release both buttons -- the LED should come on and stay on.
3. Press the larger fob button for a second, and the LED should flash.
IF re-synchronization doesn't work, you may have to replace the fob. Call customer service with your PIN (on the key-card that came with the keys). IF you don't have the PIN, then you need to call customeor service to confirm/register your ownership of the car.
If the keys are re-synchronized and it still doesn't work:
Re-program.
1. Re-synchronize as above, if you have not done so.
2. Turn the ignition on 3 times within 7 seconds. The red light above the odometer should light and stay on for 3 seconds.
3. Enter the PIN. Immediately after the red light goes out as per 2 above, switch on the ignition and count the number of flashes until it equals the number of the first digit on your PIN, then turn the ignition off, then on again. Do this for all four numbers.
4. What a pain, but if you get it wrong on a count, then you can restart by turning the ignition off for 10 seconds.
5. After the fourth digit, if the PIN is correct, the red light will stay on. Then you can re-test the fobs, and it should work.
Otherwise, call customer service.
Hope this helps.
Jan 02, 2009 | 2005 Lotus Elise
Sr Smith PoolSonix Pool Alarm Logo
98 people viewed this question
Top Sr Smith Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Sr Smith Pool and Spa Expert? Answer questions, earn points and help others
