Question about WiFlyer WDB20B 802.11g/b Wireless Adapter
WiFlyer security I got my WiFlyer connected to my laptop OK, but when I clicked on the "Connect to the Internet" link, I got a message that said the connection was unsecured. When I clicked on the Security link on the left-hand side of the WiFlyer home page, nothing happened and I never got connected to the Internet.
  • 1 more comment
  • Anonymous Jun 20, 2008
    THis product worked great for approximately 6 months on my laptop and a couple of weeks ago, it stopped working. I'm not sure what happened,
    maybe it was something I done of something that just happened. I had a technician check it and he couldn't get it working either. I have tried a new connection but it won't work either. I can't get the Dial Up Page to come up on the laptop now. Should I delete all wireless connections then try to set up a new one? Could the router be defective?
  • sugarmtn6 Jul 09, 2008
    Same here! Cannot program the wiflyer to dial my provider! alwaysonlinewireless.com is gone! Recorded message at Wiflyer's 800 support number says call back later! Web page blank! Where did they go? Were they bought out? By who?
  • mr2karaoke Jul 13, 2008
    same here, it sound like it is going to connect then says it failed. we tried calling the 800 tech line anything to get some help. no luck. this happen a few months back and then it started working again. again this time. what is the issue. we all have jobs and this is what we use for them. I rebooted the wiflyer box did all of the toubleshooting which we received when it would go down with no luck.
    help.
    Genius:
  • 3,422 Answers
The router says unsecured when you've not set a password fro it.I mean WEP or WPA key..
Goodluck..
Posted on May 08, 2008
Can't connect to internet,Computer says i am but can't browse still
Wireless Zero Configuration was first introduced with Windows XP. In Windows Vista it was renamed to "WLAN AutoConfig".
Wireless Zero Configuration (WZC) or WLAN AutoConfig is a service included with modern versions of Microsoft Windows that dynamically selects a wireless network to connect to base on a user's preferences and various settings. This can be used instead (or in the absence) of a wireless network utility from the manufacturer of a computer's wireless networking device.
To join a wireless network:
  1. Open the Start menu and click Control Panel.
  2. In the Control Panel Home window, click View network status and tasks.
If you are using Classic View, double- click Network and Sharing Center
Click Connect to a network.
Select your network from the list and click Connect.
If security is enabled on the network, you will be asked to type your network security key or passphrase for your AP/router. After typing security key, click Connect.
and keep follows the prompt.
Apr 30, 2013 | WiFlyer - Portable, shareable WiFi base...
Compac CQ210us laptop
Open Network and Sharing Center, at the top of the page, the illustration, Is it connected across the top to Internet, or just say Local? Post results
When i connect to laptop i get connection terminated with error code 734
If you try to establish a Point-to-Point Protocol (PPP) dial-up connection, you may receive the following error message: Error 734: The PPP link control protocol was terminated. As a result, you cannot establish a dial-up connection.
This issue may occur if either of the following conditions are true:
  • Multi-link negotiation is turned on for the single-link connection.
    -or-
  • The dial-up connection security configuration is incorrectly configured to use the Require secured password setting.
To resolve this issue:
  1. Click Start, point to Settings, and then click Network and Dial-up Connections.
    NOTE: For Windows Server 2003, click Start, point to Control Panel, and then point to Network Connections.
  2. Right-click the appropriate dial-up networking connection, and then click Properties.
  3. Click the Networking tab, and then click Settings.
  4. Click to clear the Negotiate multi-link for single link connections check box (if it is selected).
  5. Click OK, and then click OK.
  6. Double-click the connection, and then click Dial.
    • If this procedure resolves the issue and you can establish a dial-up connection, you do not have to follow the remaining steps in this article.
    • If this does not resolve the issue and you cannot establish a dial-up connection, go to step 7 to continue to troubleshoot this issue.
  7. Right-click the connection, and then click Properties.
  8. Click the Security tab.
  9. Under Security options, click Allow unsecured password in the Validate my identity as follows box, and then click OK.
  10. Double-click the connection, and then click Dial to verify that you can establish a dial-up connection.
May 11, 2011 | Computers & Internet
When i install the router which is connected to a cable modem, using the setup cd i get an error message stating that the internet is not connected, the desktop pc which is connected via cable can access...
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
Apr 29, 2010 | D-Link DIR-615 Wireless Router
Proxy Settings in Vista
You have to disable your proxy settings from internet explorer.
Open internet explorer.
Click on tools >> internet options >> Connections
>> LAN settings >> uncheck everything
and then click on ok >> ok
and then close internet explorer and check your outlook is working well or not.
Mar 29, 2010 | Microsoft Computers & Internet
I forgot my user mname and password for my wifi connection
You can secure your wireless network wit WEP or WAP code.
For know your security key Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
The old password is in * or # format so you need to enter new password.
Let me know if you need furhter assistance.
Thanks for using FixYa
Mar 26, 2010 | WiFlyer - Portable, shareable WiFi base...
Cannot connect to the internet. message reads firewall/query user.
Hi there.
With WinXP go to the control panel select security center, click on manage security settings for windows firewall, click on the advanced tab and then click on restore defaults, it will give you a warning but click ok and it will reset.
With Vista go to the control panel select security center, in the top left of the window click on windows firewall, then select change settings, click on the advanced tab and carry on just like with XP.
When you have reset the firewall to defaults its recommended you restart the PC.
Please post back with the results and thanks for using FixYa!!
May 25, 2009 | Dell Computers & Internet
Cannot find local area connection to access internet
IF YOU HAVE A ICON OF A COMPUTER AT THE BOTTOM OF THE SCREEN IN THE BOTTOM BAR CLICK IT AND YOU SHOULD KNOW WHERE TO GO FROM THERE
Dec 22, 2008 | WiFlyer - Portable, shareable WiFi base...
Have just bought a computer second hand and have just got internet running with 100% signal but cannot connect because we cannot find local area connection to access files
As dragoness1 says, you don't need a LAN to connect. Right click wireless icon in system tray (bottom right of screen), select "show available Wireless networks". Select one and click connect. If they're not from your own Internet service, they may be protected by a password.
D-Link DI-524 AirPlus G - Laptop Cannot Connect to the Internet
Go to control panel>network connections, right click, then properties, then click the TCP/IP line, properties again and ensure that 'obtain ip address automatically' is ticked, click ok,  then close down the window, right click on the network icon again and then properties, then view wireless connections.
Any that appear in this list including your own if it shows need to be deleted, then when you close the window a pop up should appear in the task bar saying wireless networks detected, click the bubble then highlight your connection, click connect and if security is turned on you will be prompted to enter the passkey.
In the routers settings ensure that DHCP is enabled to allocate ip addresses automatically, then reboot the router if neccasary.
Oct 22, 2007 | D-Link AirPlus DI-524 Wireless Router
WiFlyer WDB20B 802.11g/b Wireless Adapter Logo
172 people viewed this question
Top WiFlyer Computers & Internet Experts
Frank Zabroski
Frank Zabroski
Tom Chichester
Are you a WiFlyer Computer and Internet Expert? Answer questions, earn points and help others
