Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Mold under rubber ring (seal) around door
Has anyone had this problem and how have you resolved the problem? My washer smells too and have tried bleach and vinegar (separately) and hasn't helped. Any other ideas there would be appreciated!
  • Wayne Morgan
    Wayne Morgan Nov 22, 2008
    FOUND BUILD UP IN SAME AREA
  • 5,911 Answers
This is a common problem associated with frontloader style washers. Click on the link below and it explains why this can occur and what you can do to prevent it in the future.
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I hope you find this information helpful. If you need further advice, please let me know.
Posted on May 08, 2008
How to clean my washing machine Electrolux Front Loader
Hello -
First rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Sep 21, 2012 | Electrolux EW1000i Front Load Washer
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer smells
Hi
Thanks for using FixYa. To resolve the issue please start the washer with one cycle using only bleach and detergent. Then run a load of clothes with vinegar and detergent in it. Most probably the smell is coming from the bleach dispenser. Please check the bleach and fabric softener dispensers. If still the problem persists then you need to check the hosepipe that it is not having fluff or trash. If so, then clean it and the issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 05, 2009 | Magic Chef Washing Machines
Smell in washer
Vinegar will fix this! Try pouring a quart of white vinegar into the washer, then run a cycle with no clothing in the washer. When the rinse cycle begins, stop the washer. Let it sit for about 30 minutes, then complete the cycle. That should do it! Afterwards, be sure to leave the door open to air dry it.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
CLEANING OUT CAT DANDER ETC FROM WASHER
Quenie, vinegar will not harm your washer at all. Place it in the detergent side of your dispenser and run a Hot wash cycle. Don't mix chemicals, though... if you choose to clean your machine with bleach, for instance, don't use additional cleaners along with it. Vinegar only, bleach only... you get the point.
You may want to run a "water only" Hot wash cycle with bleach (no clothing/towels) after your Son has finished his laundry. This may help alleviate your allergy problem.
For regular maintenance on your washer, you ought to try something like this. It'll keep your washer smelling great.
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
120 people viewed this question
Sal De
fordexpert
Robert Rankin
