Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht has f21 on screen - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
ERER CODE 5D?
Whirlpool Duet Sport ht 5D/F21 Error Fix - YouTube
? 5:40
https://www.youtube.com/watch?v=2dV3FLzWPTM
Aug 6, 2013 - Uploaded by Mariela Gonzalez-Aroche
Steps in this video may be used to repair both F21 and 5D error codes. ... which is located on the bottom right corner of thewasher machine.
Nov 01, 2015 | Washing Machines
I have an error f21, u cleaned and cleared everything out of the line and i still have the f21 error code
Open the back of the washing machine in the middle towards the bottom you will see another piece that is connected to an air hose. That is supposed to be a light clear plastic. If it is dark it may also need to be cleaned. Mine was also clogged there and I did not find any blog on cleaning that. Also, after cleaning that it could be that the air hose to the pressure switch has a hole in it which was just a $3 part.
Good Luck!
Jul 11, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F21 lights up or 5d water won't completely drain on cycle
If you have anymore questions please feel free to ask, Rich.
Jan 21, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet washer that on the display is flashing F-21 what does this mean?
“F21” on display (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Feb 13, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
F21 showing on screen
Take the bottom panel off of the washer and there should be a instruction guide in the washer that will tell you what the error code indicates.
Apr 01, 2009 | Washing Machines
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
222 people viewed this question
Dan Webster
Dan Webster
Sal De
