Question about Garden
Weed eater model 1216 manual? - Garden
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
  • 112 Answers
SOURCE: gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Posted on Jul 25, 2009
Dolfoff
  • 148 Answers
SOURCE: looking for information on a weed eater riding mower
On the center of this page click "Parts Look Up".
Next, Change the tab at the top to "MODEL".
Next, Drop the "Select OEM" menu down and choose "Electrolux Home Products".
Next, Under "Model Search Criteria" select the option "Contains" .
Next, Under "Model Name / Number" type in we12542 (do not use spaces or dashes).
Next, Select the proper letter-code that is listed on your machine. (Same info sticker you found your model number on.)
Next, Select the specific component drawings which will be listed on the right side of the page.
Hope this helps
Posted on Sep 28, 2009
  • 279 Answers
SOURCE: Where or how can I get an owner's manual for the
They can be found online. I used to know the address but don't have it any longer. Just keep looking, I know it is there...Lee
Posted on May 28, 2010
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
Lost manual does this weed eater take regular gas or is it a mix
Want to give us a hint as to what kind of weed Eater this is? Most gas models use a mixture but the ratio can vary between manufacturers.
Jan 08, 2015 | Homelite Garden
Morrison weedeater
never saw your brand weed eater . but most weed eaters ,the string cap either unscrews or has plastic tabs that have to be pushed sideways with a flat blade screwdriver.If you have the plastic tabs ,be careful not to crack them off when pushing them sideways with a screwdriver--- so that the nub can clear the slot and get the cap off.
for better info call morrison customer service and ask.
phone # on weed eater and in owners manual. also , owners manual should have instructions under how to change string.
a pdf manual can be downloaded from morrison weed eater.
you will need to know your model number before morrison can help you.
Oct 06, 2013 | Garden
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Where or how can I get an owner's manual for the Weed Eater Model 115?
May 28, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
May 16, 2010 | Garden
New wife has cc4125. How do you replace trim wire
Hello South Texas from former Mesquite resident!
If this does you any good, get your Model and Serial no. and can go to this web address and download the owners manual:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=30000
Sep 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Where can I find a manual for the PE550 weed eater
You can download one online at... http://www.poulanpro.com/poulanpro/indexAction.do?id=default Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
May 21, 2009 | Poulan Garden
Garden Logo
220 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
