Question about Roper RAX7244KQ Top Load Washer
The washing machine is rusted under the lid. How do I take the top off so that I can repaint? The model is RAX7245KQO. I need to take the top of the cabinet off to repaint. I need directions as to how to get the top lip off the machine.
    Scholar:
  • 97 Answers
You have to use ether a screwdriver of a wedge in the seal about a inch below the top and pry up it is held by strong spring clips it will take some work when done you just pop it down unplug unit first hope this helps
Posted on Aug 30, 2010
My Kenmore 20902 washing machine lid is rusted. I...
Hello, Guest who?
Getting the lid off of your Kenmore is simple. Raise the lid. At the bottom on each side are a pair of screws that go through the lid and attach to a reinforcing bracket on the inside. Take these screws out, remove the bracket, do the same for the other side. A small bowl or ziplock will keep these small bits from getting away. When you have repainted or replaced the lid, insert the bracket with the loop down, and insert the screws from the outside through the lid.
Done!
May 19, 2010 | Kenmore 24032\24036 Top Load Washer
Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
Rust under lid and top of barrel.How do I open up the machine to remove rust and paint?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0117d74bc3bdabe782b54341ddab128a
Jan 19, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine insert is rusting
You should contact Kenmore, most inner wash tubs came with a lifetime warranty, you would have to pay for the labor but they should cover the part. Good luck !
Jan 05, 2010 | Washing Machines
Rust on the lid
You will need to use steel wool to lightly scour off all rust, Then you should use an enamel paint or clear fingernail polish to repaint the area.
Oct 11, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper topfill washer fills, washes but will not spin. Type: 107 Max.: RAX7245KQO Serial: CL 3617156
Did you check the lid switch? continuity would tell you, simply remove the two screws for the top (timer consol) phillips screws . then you will see a white plug on the cabinet disconnect it then shut the lid or stick a pen/ or something to activate lid switch stick your ohm meter in the 2 end holes, make sure you have no electricity and check with continuity.here is the lid switch for your model
Apr 24, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Kenmore elite washer lid removal?
how do i remove the washing machine the top
Oct 20, 2008 | Washing Machines
Kenmore Washer Model 110.28974890
Yes you can. Searspartsdirect.com carries all the parts you need to replace the washer lid. Just type in the model number you provided and look under the "Top and Cabinet" heading for item number 19. Pay particular attention to the part numbers. There are two listed. One is for a WHITE (part #3952141) lid and the other is for an ALMOND (part #3952146) colored lid. I hope this helps you.
PS This was the cheapest site I could find the lid. If you still wish to do some comparative shopping, use the part numbers provided by the Sears website for your search.
Oct 06, 2008 | Kenmore 24032\24036 Top Load Washer
Corroded lip
Need to know what you are referring to as the top. Do you mean the lid or the chassis top.
The actual top section is bolted from the inside.
Dec 19, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAX7244KQ Top Load Washer Logo
150 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
