Question about Dell UltraSharp 2007FP (Black) 20.1 inch LCD Monitor
My dell 2007fp monitor has a greenish type band going from top to bottom on the left hand side,any ideas as to what the problem might be
rosener
  • 103 Answers
SOURCE: Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Posted on Jan 30, 2008
  • 55 Answers
SOURCE: Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Posted on Mar 14, 2008
graysand
  • 558 Answers
SOURCE: laptop monitor has a 2 inch black band along ride
You may have a bad display or a bad converter.Have you tried reinstalling the video drivers?However you may try reseating the lcd cable which is attached to the mother board or the inverter which sits just below the lcd itself,behind the lcd bazel.Remember if you are going to attempt this you must remove the battery and the ac power.
Good luck
Posted on Sep 14, 2009
  • 7 Answers
SOURCE: Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
Posted on Oct 10, 2009
  • 541 Answers
SOURCE: Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Posted on Nov 30, 2009
Testimonial: "Thank you for your reply but this looks like something that I do not want to try to remedy myself! Thanks again for you time!!"
How to remove back of dell 2007fp
This guy made a great video series of how to. Make sure you thank him for his work.
https://www.youtube.com/watch?v=RXAQxwCTuuI
Nov 22, 2012 | Dell UltraSharp 2007FP (Black) 20.1 inch...
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
I have a Dell 2408WFP monitor which was purchased in November 2008 and has just developed three vertical black stripes side by side and about one pixel in width down the right hand side. I contacted Dell,...
Well it seems to me you have a dead pixel issue. As soon as you call up a company like Dell and tell them that they know they have to replace the unit.
Either ride it out, or replace the actual LCD part of the screen. Which can not only be costly but rather complicated as well... If you want to go down this avenue then take apart the back of the unit carefully and remove the whole screen unit inside the plastic housing. The screen unit should consist of 3 glass thin slabs and a plastic type screen over the front wrapped together by a sticky reflective tin-foil type substance. Thats the unit you need to replace... Make sure you remove the back-light lamps from the top and bottom of the unit carefully, as if you break these your heading down a whole new avenue of issue...
On the back of that device will be a part number...
www.sparepartswarehouse.com
go there, type in the product number and it will search their database for a replacement part...
Another option is to search ebay until you find an AS-IS deal on the same make/model with an instact screen... Which requires patients and your always taking a risk doing this...
May 09, 2011 | Dell UltraSharp 2408WFP 24" LCD Monitor
Dell 2007FPB LCD Won't turn on nothing happens when the power button is pressed
Hi and welcome to FixYa!
As a first course please check the monitor power cable. It may be a little loose that's why its not powering up.
Hope this helps and thank you for using FixYa!
Dec 02, 2010 | Dell UltraSharp 2007FP (Black) 20.1 inch...
About a week ago my Dell 2007WFPb LCD monitor (purchased in 2007) flickered on and off PIP mode, and would not stay on one setting for PIP for longer than 2 seconds. It was not fixed and now the power...
Not the power cord problem at this point, more likely to have failed Power supply or Inverter board.
http://lcdrepair.us/2007fpw-power.html
http://lcdrepair.us/2007fp-inverter.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 15, 2010 | Dell 2007WFPB LCD Monitor
Grey Band and Ghosts on monitor
check the playback and other chips inside.. or try to change the setting menu the setting in your remote or manuall change
Jun 25, 2009 | Samsung SyncMaster 203B LCD Monitor
OR, Buy a new one.
Mar 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical band on new monitor
Without a second thought, send it back.
When you say the monitor has not be dropped, wht you are really saying is it has not been dropped by you.
There were alot of hands involved in getting it from the production line to your house.
At any stage it could have been dropped or given some form of impact (normally in transit)
That fault is in the panel itself and cannot be fixed.
Nov 06, 2006 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp  2007FP (Black) 20.1 inch LCD Monitor Logo
Alun Cox
