Question about Dell PowerConnect 2624 (p2643np) 24x1000 Mbps Networking Switch
What i sthe defaut ip to connect to this swicth? I need to reprogram after power loss.
  • 131 Answers
That is not a managed switch. It is not programmable. Get the network servers running first and then the devices connected to the switch should start pulling IPs and regaining connectivity.
Posted on Aug 30, 2010
Default addrss
Connect to the wifi network called instant and then check in the properties of the connection the IP address of the DHCP server. This is the address of the Ap 175. We worked with some of them and they had the virtual connector configued with the IP address 192.168.10.1
Aug 29, 2013 | Aruba Networks Aruba AP 175
Power on itself when main swicth is on
If didnt turn it off in Windows properly it will assume you have loss of power.
Mar 27, 2012 | Dell Inspiron 1525 Notebook
No matter what i do i cannot enable TCP/IP or Parallel port. I enable through the system setup but when the fiery restarts and and the test print is printed it just keeps telling me TCP/IP enable :NO and...
Is not simple if you don't the program. It find in www.support.xerox.com . When you install the driver , please connect the printer, TCP /IP must be static IP and not DHCP. Because the ip is change when the swicth is desconnect.
Nov 03, 2010 | Xerox DocuColor 12 Printer
I have a problem with my nokia 5130c-2,when i swicth on my mobile it indicate CONTACT SERVICES an swicth off by it's self
your phone needs a reprogram if there is no history of drop or physical contact that is not meant for phone.
Oct 13, 2010 | Nokia 1600 Cellular Phone
3110c Cant switch on
it needs to e reprogram.. please vote
Jun 08, 2010 | Nokia 3110 Cellular Phone
MY WIRELESS-G LINKSY 54G NOT DEFAUT IP ADDRESS 192.168.1.1 BUT DEFAUT PRIVATE IP
The Linksys configuration URL IP address is 192.168.1.1 this is used to configure the Linksys wireless settings.
The Linksys is also a router and will issue IP address to eack computer that connects to it (LAN and wireless). it will start issusing IP addresses starting at 192.168.1.2 and the last number will increment by one digit as each computer connects to the Linksys.
Jan 21, 2010 | Linksys Wireless-G WRT54GS Router...
How do I secure my DLink-524 wireless
In securint your wireless security try accessing the configuration page of the router. go the the window where you created your wireless netowrk connection.
On that Wireless window choose WEP for security.
By defaut WEP Encryption is 64bit.
Under Key1 erase what's on the box and type in the password for your wirelss network. It should be exactly 10 characters, You could use 0 to 9 or A to F then click on Apply >next.
Try Accessing your wireless networ.
Nov 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Reprogram my router
Theres no need to "Reprogram" your router.
A) Remove the power cable from the back of your router.
B) "Reboot" your DSL modem. In some cases there is a reset button on the bottom or back of the DSL modem. In other cases you must remove the power cord then remove the battery - then put it back together.
C) One the DSL modem has power, restore power to the router.
D) I would at this point reboot your PC in case a new IP was assigned (Unlikely, but to be safe)
Nov 27, 2007 | Linksys EtherFast Cable/DSL Router
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Dell PowerConnect 2624 (p2643np) 24x1000 Mbps Networking Switch Logo
203 people viewed this question
Alun Cox
