Question about Weber Genesis Silver B Grill
I have a weber genesis silver. It was working fine, the next time I went to use it, the flame only goes to a medium level. Hi and medium are the same but it does reduce to low. Its the same with the extra burner. I tried cleaning the grill out (pan, and also the 3 gas lines), using different tanks of gas, and even trying to set the knobs a bit closer to the off position. Still the same. Very little orange flame. The middle gas bar also lights very slowly.
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Weber Genesis with a low flame! I've replaced the reglator twice and each time it works for a bit then the flame goes down to almost nothing. There seems to be screen protecting where the...
if you can take the burner out and try blowing air down it see if this clears , check injector is not block, check gas line is not blocked , or try new burner
Sep 05, 2011 | Weber Genesis Silver B Grill
Have a 15 year old Weber Genesis. Recently filled the tank, and was working fine. Today, went to fire it up and barely any flame coming out of the burners. In fact, when I turn on the middle burner, the...
You need to completely change the grill because it's been there for over 15years and alot of rust and linkages will after affected the grill from working properly well.The best bet is to get a new grill.
Nov 25, 2010 | Weber Genesis Silver B Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Two burners run too hot with yellow flame.
It sound like your back burners have a partial blockage or possibly are rusting or falling apart or have cracked seams. Remove the cooking grids and burner shields, and examine the burners closely. If you can't find a blockage inside (spider web, bugs nest, etc) then their condition is probably deteriorating. Let us know if you need more assistance.
May 21, 2010 | Weber Genesis Silver B Grill
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
Low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Mar 14, 2009 | Weber Genesis Silver B Grill
Uneven heat from burners
I'm experiencing the same problem, the left side has the least heat, and it seems to be getting way worse over time.  Has anyone found a solution for this yet?
Oct 17, 2007 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
299 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
