Question about Rowenta Professional DX8900 Iron
I have some kind of buildup on my Rowenta Iron. How can I remove it without damaging my iron?
  • Rowenta Master
  • 43,501 Answers
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
heatman101
Posted on Aug 31, 2010
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
Does red light suppose to flash
follow this section troubleshooting and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2013 | Rowenta Effective DX1900 Iron with Auto...
Shoots out through the steam vents and sains clothing
The symptoms you describe are indicative of mineral buildup in your iron. The instructions probably say to use distilled water in the iron and may include a procedure for removing mineral deposits
Jan 14, 2013 | Rowenta DG-980 Iron
Calcium buildup - when ironing white specks keeps getting on clothes.
<span id="LblAnswers">.To solve this problem, switch to bottled spring water. Once the water is changed it will take several uses before your iron adjusts to the new mixture and the issue is corrected. </span><br>to speed that up Place the iron in clean or high stream mode if its a feature on your iron if not I would wipe it down with the solution usually 3 parts water 1 part vinegar.&nbsp; Also Rowenta sells a cleaner specifically for their irons&nbsp; and you can purchase it online here is the link its from macys but rowenta brand and is now on sale <br><br><a href="http://www.macys.com/catalog/product/index.ognc?ID=64754&amp;cm_mmc=Google_Feed-_-6-_-77-_-%7Bkeyword%7D&amp;kw=%7Bkeyword%7D">http://www.macys.com/catalog/product/index.ognc?ID=64754&amp;cm_mmc=Google_Feed-_-6-_-77-_-{keyword}&amp;kw={keyword}</a><br>
Aug 29, 2010 | Rowenta Irons
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
2 screws on bottom of iron are rusted
they do take a special tool. However I have used an allen wrench and it will remove them. Take them to a local hardware store or sears and get the same screw thread pitch in stainless steel and with a phillips or slotted head
Dec 30, 2008 | Rowenta Powerglide DM273 Iron
How to clean
heres a link to help you out , also I recommend to get "CLR" cleaning product , hope it helps AJ
Jun 12, 2008 | Rowenta DX6700 Iron
I have a Rowenta Professional iron that is spitting sometning onto dress shirts and leaving permanent marks. There does not seem to be anyone in Winnipeg, Manitoba Canada that can address this problem. ...
The iron probably needs to be cleaned. You can use half water and half white vinagar to clean. Hope this helps. Those white pieces are mineral deposit buildup.
Apr 01, 2008 | Rowenta Professional DE880 Iron
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Dec 04, 2007 | Rowenta DX6700 Iron
Rowenta Iron
TO CLEAN THE BOTTOM OF THE IRON, MY NAN USED TO ALWAYS IRON BROWN PAPER, IF THIS DOES NOT WORK, USE A RAG DIPPED IN THINNERS, OR LIGHTER PETROL AND RUB GENTLY.
NORMALLY THE SELF CLEAN SYSTEM IS JUST A BUTTON NEAR OR ON THE TANK THAT YOU PRESS WHILE THE IRON IS ON AND HAS WATER IN, PRESSING THE BUTTON WILL FORCE WATER THROUGH THE STEAM JETS (SO KEEP IRON FACING DOWN) ALSO EMPTY THE IRON AFTER EVERY USE
Nov 27, 2007 | Rowenta DE-480 Iron
Rowenta Professional DX8900 Iron Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
