Question about Kenmore 64992 Electric Dryer
Kenmore model #86982800
Dryer was working then i moved it and it won't start kendrlyn@aol.com
    Genius:
  • 1,073 Answers
Check power cord connections for tightness with the power OFF
Posted on May 08, 2008
417.84052500 electric dry 05 model safe mode code. Everything lights up but won't run
Rocky, Could be door switch problem.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bypass dryer door switch Whirlpool
Dryer Not Starting How to Test the Door Switch
. Whirlpool Kenmore Dryer Repair 01 Won Start or Run Door Switch 3406107...
http://www.selfhelpforums.com/archive/index.php/t-10060.html
Mar 13, 2016 | Kenmore Dryers
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
I have a kenmore 90 series elec dryer. Model # 110.64924200. When I turn it on it won't start, however I can hear it click. Like a car turning over but won't fire. Any suggestions? Already cha
the start relay in the control panel is bad,the relays coil is moving this is the click you hear,but the main contacts in the relay are bad there are 4 wires to it 2 for the start switch and 2 for the main contacts
Oct 24, 2012 | Kenmore Dryers
My dryer will not start. It is Kenmore model# 110.62622101. There is power and the door clicks closed but it will not start.
Hi and welcome to FixYa, I am Kelly.
Try this first: Reach inside the drum and move the dryer drum by hand for about 1/2 revolution SLOWLY. Move the drum in a CLOCKWISE direction so you do not cause the ifler pulley to fly off. Then try a start.
If this does not makeit run then the next step is to make sure there is power at the push to start switch. Item 5 this link: (You accept responsibility for working on live circuits)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11062622101/0582/0151200/P0110200/00001?blt=06&prst=0&shdMod=11062622101
Then you check the thermal fuse item 1 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11062622101/0582/0151200/P0110200/00003
Most likely the thermal fuse has failed.... the reason these fail is due to poor air-flow. Clean everything... wash the lint filter with vinegar and water, then soap and water. Vacuum all the internal ducting and the lint filter cavity. Use a folded wire coat hanger if necessary to knock the lint free so you can vacuum it out. Go outside and check the thru the wall vent flapper for blockage. THEN replace the thermal fuse. Turn on the dryer and check air flow with the rear ducting disconnected. It should push a relaxed hand gently away from the duct connection. If you do not have this kind of air flow after an avid cleaning and lint removal session... there is most likely a problem with the blower wheel spinning on the motor shaft / broken fan hub. Blower wheel / fan is item 37 of this link:
The other possibiliies are the motor switch and the timer. Most of the time the problem is the thermal fuse failure due to lint build up.
Thanks for choosing FixYa,
Kelly
Jun 18, 2011 | Kenmore 72982 Gas Dryer
Circut breaker turned off then turned on dryer wont turn back on (kenmore serial #86982800)
i ve seen this in the field alot of times make sure you actually are getting full 220 to unit.. sometimes these dang breakers look like they are on but they fail to send full power back to unit... it is even happened to me in the field i go to turn power off to a customers unit and when i am ready to turn back on the breaker wont fully reset... check it out if it was working prior to the bresker turned off and you didn't operate on the dryer disconnecting or replacing anything this is your problem...
Jan 02, 2011 | Kenmore Dryers
My dryer (kenmore elite model 110.64992300) wont heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 26, 2010 | Kenmore 64992 Electric Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore 64992 Electric Dryer Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
