Question about Panasonic PT-50LC13 50" Rear Projection HDTV
I have a panasonic 62 inch LIFI DTV 1080P tv The problem is when i turn on the tv the green light flashes tv does not come on and after a couple minutes shuts off itself , i have unpluged the tv for a day to see if that works and even put the plug in a different outlet still no sucess the tv is just over a year old any advice to what i might be
I have a Panasonic 62 inch projection tv there is a bright green patch at the top left corner, need help to fix this
Posted on Jun 17, 2012
Mr_Mick
SOURCE: Panasonic TV Shuts off by itself
I had the same problem , Good sign of a cold solder or cracked trace.
On my PT51HX41 after a long check with a magnifying glass I found the problem on the main board just below the AC daughter board there is a Blue rectangular box (relay R801) and it had two cracked solder joints.
Posted on Feb 22, 2009
SOURCE: I have a Panasonic PT-56LCZ70 LIFI? Projection
Did you ever solve this problem? I have the same problem with mine now and it's only 2 years old. Thanks
Posted on Jul 16, 2010
MikeNJ1964
  • 398 Answers
SOURCE: Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Posted on Aug 23, 2007
SOURCE: Panasonic PT-47wx53, No power, 3 Blinks
Panasonic PT53WX42F with same problem. 3 blinks after power on for a few seconds, no picture or sound. Solution: replaced two convergence ICs (STK392-XXX) located on the large green printed circuit board. ICs are very large and screwed into two large heat sinks and soldered to board. Cost is approximately $6 each. Easy to replace if careful. May be able to access solder joints on bottom of board by removing screen on bottom of cabinet or simply remove 4 screws that anchor plastic holder to cabinet and tilt up. I did not disconnect any inter-board connections. Remove heat sink screws. Desolder using suction bulb or solder sucker. Works great. Finish off with solderwick braid if necessary to clear holes. 40 watt iron is enough do not apply too much heat to damage board lands. Remove IC. Clean heat sink by scraping away white heat sync compound. Apply generous amount of heat sync compound to new IC and coat evenly. Align and insert new IC holes, resolder with thin resin core solder being careful not bridge lands. Refasten to heat sink. Clean board and inspect for good joints and no bridging. Refasten plastic board holder. Carefully clean projection lenses while back is off tv. Power up and it should be fixed. Parts are obtainable on-line. Solder tools and board cleaner are available at Radio Shack or on-line also. I spent $20 on parts and supplies. This is not hard just a bit tedious. You can do it.
Posted on Jan 04, 2008
  • 556 Answers
SOURCE: my panasonic (pt50lc13) keeps shutting off after a few minutes.
probably lamp gone out. You can change it youself if you still have owners manual should have directions, if not most lamps have instructions in box.
Posted on Aug 11, 2009
TV turns off with orange light flashing 6 times. Happens twice a day
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience
Jan 09, 2016 | Panasonic Pt-61lcz70 61-inch 1080p Lifi...
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
1080p PT56LCZ70, won't turn on, green light flashes for a while and then the red light flashes twice, pauses for a second or two and then flashes twice again, continues to repeat this over and over. What...
I have the same problem with my Panasonic PT56LCZ70, after check the test points, I'm sure its the "LIFI 4000" Lamp, and I think its a faulty part in all kind of those Tv's
Jan 15, 2011 | Panasonic PT-56LCZ70 56" HDTV
My panasonic lifi tv starts flashing green then the red light flashes red all the time now.
If the light is flashing 2x and pausing and repeating you probably need a new lamp.Panasonic has extended the warranty on the labor for the lam p to 3 years due to difficult replacement.Call Panasonic customer service and they will refer you to the nearest service center.The lamp itself is covered for 5 years.
Nov 10, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
MY PANASONIC LIFI TV STARTS FLASHING GREEN THEN THE LAMP LIGHT FLASHES RED TWICE
Try replacing the lamp, if its been more then 2years since purchasing the television
Oct 18, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Problem with my 61 inch LIFI
I had the same problem, turned out to be the bulb, had it replaced and now I`m having problems with the new bulb (dark picture).By the way the first bulb lasted only 8 months and it has been 8 months since the new one was put in, so much for the 5 year bulb.
Mar 27, 2009 | Motorola Mobility DRC800 Universal Remote...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
597 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
