Question about Maytag Washing Machines
Have a Maytag Centennial Commercial Technology washer. It did not spin the clothes well on the "Regular" wash, so I turned the dial to "spin" again to give it an extra spin, and now everything is out of sync. How do I get it back to doing what the dial says it should be doing? The machine is less than 1 year old.
Coldcut
  • 1554 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
Posted on Jan 26, 2008
clusterfx
  • 67 Answers
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
Daniel S
  • 4323 Answers
SOURCE: Hi My maytag centennial commercial
Hi
First of all please use less load then you are using right now. If still it is not agitating then it seems that something is stuck and you'll have to remove the agitator to clean it. Also check if the door is getting locked. If the door lock-switch assembly is bad the control won't detect that the door is closed and so will not spin. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 21, 2011
  • 5417 Answers
SOURCE: Owner's Manual For CENTENNIAL Commercial
Maytag has many of the manuals for their washers available at their site. Go to https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10562&langId=-1&storeId=10212&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView and enter the model number of the washer.
The direct link to the manual for the Maytag Centennial MVWC6ESWW1 is https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10330943.pdf . Additional manuals are available here https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212 . (This includes the manuals in Spanish, installation guide and parts list.)
I hope this helps.
Posted on Aug 06, 2011
My maytag centennial commercial technology washer the sensing light keeps blinking and the lid want lock what do I do.
Wipe around the inner edges of top and ledge where door meets with machine to close. removing any particles of debris. then using a pipe cleaner carefully swipe out the opening where the locking unit is on door and machine latch. again ,removing debris
Jan 24, 2016 | Maytag Washing Machines
Maytag centennial washer
Most likely pressure sensing switch. What is your model #? If your model has this part # W10292584 then it is the problem.
Nov 11, 2017 | Washing Machines
Owner's Manual For CENTENNIAL Commercial Technology Washer - Model No. MVWC6ESWW1
I hope this helps.
Aug 06, 2011 | Washing Machines
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Washing Machines Logo
855 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
