Question about Brother DCP-7020 All-In-One Laser Printer
I am getting several black lines in scanned and copied documents of my DCP 7020 Thanks
    Scholar:
  • 88 Answers
Check the print document to see if the ink rub of easily,if so this mean the fuser cartridge need to be change.Turn off the printer and wait until it is cool before changing the fuser cartridge because the fuser get very hot when ever the printer is in use.
Open the fuser cartridge door. On most printers this door will be either on the left-hand side of the printer or in the back. Consult your owner's manual for the exact location. Flip down the clips that hold the cartridge in place, then grasp the handle and pull it out of the printer.
Push the new fuser cartridge in until it snaps into place, then flip the clips up to lock it in place. Close the fuser cover door.
Open the toner cartridge door and remove the toner cartridge. On most laser printers the toner cartridge is located either in the front of the printer or on the right-hand side.
Vacuum underneath the toner cartridge to remove all paper dust and toner residue. This debris has a tendency to build up and cause streaks and stains on the paper.
Wipe the interior of the printer with a soft cloth to remove any remaining debris that could cause problems with print quality. Continue cleaning the printer until all debris is removed.
Purchase a set of laser printer cleaning sheets, and load one or two in the paper tray. Print to those sheets of paper to clean the paper path. These sheets are slightly sticky, and they are designed to remove dirt and debris from the paper path.
You should also clean the print drum and the corona wires.
Posted on Aug 30, 2010
4 wide horizontal blurry lines in printed document
Either sensitive drum of the tonner is damaged or the high temperature fuser roller damaged. Check and replace.
Nov 17, 2015 | Brother DCP-7020 Laser Multifunction...
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
How to remove a black line off scanned papers
Black hair lines can come from what is called the slit glass. Does the line appear when you can from just on the glass? If that scan is OK and the line appears when you run through the document feeder than the small glass just before the top glass needs a good clean, or sometimes in the machine the optics has some dirt on it.
Jul 22, 2014 | Brother DCP-7020 All-In-One Laser Printer
I have a Brother DCP 7020 copier. I have in my
I dont understand your problem but if you like this telefone numbre 1-888-800-7303 is a technical support of Brother.
Sep 29, 2009 | Brother IntelliFax-2820 Laser Fax
Brother dcp 7020 Scanning to e-mail
with Brother -photo capture-copy-fax-scan machine, I can do except scanning. Please show me how to enable scanning
Feb 01, 2008 | Brother DCP 7010 Multifunction Laser...
Black line in center on manual feed
If you are getting marks on copies but not prints then it is the small slit of glass prior to copy glass that is marked/dirty
Oct 23, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
371 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
