Machine does not let the water go out - Washing Machines
  • 2,272 Answers
If its not filling with water then its a fill valve problem.But if the machine is filling but not draining then its a drain pump problem.Either the drain pump is clogged or faulty.Remove the drain and check both the drain pump and hose to which drain pump is connected.If both checks out ok then its faulty drain pump causing this problem.Replace the pump. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
I have dwf-170 mp washing machine, the machine does not fill with water.
that is not the water pump but the inlet valves are you sure the water is turned on behind the machine
Mar 28, 2016 | Washing Machines
The water stopped coming into the machine?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
Water isnt going into the machine
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Dec 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Hot water is a small trickle into the machine - warm water gives you a bit more water coming into the machine & cold water has a moderate bit of water coming into the machine. We have extremely hard...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 01, 2010 | Frigidaire FWS833A Top Load Washer
Solis palazzo espresso maker / water tank problem
HI
Did you push the water button, before you opened the knob? When you finished descaling did the lights change? On any compact machine you need the let the pump stop on its own. Then go to the next part, rinsing. Again letting the machine stop on its own. Pump will stop and the lights will change. Once the machine has finished rinsing. You will have a steady water light and a blinking green light. Put your tank back on with fresh water, then push the water button(far right), then open the knob for water. The red light should go out, and the machine will heat again.
Dec 22, 2009 | Coffee Makers & Espresso Machines
Machine does not take water. the water does not come in to the machine. I think it can be the water pump.
Before breaking into your machine, shut off your water inlet valve(s) to the machine. Remove your water inlet hoses from the machine and aim them into the wash tub or a bucket. Check water flow through hoses. Debris in water system can clog up the screens on your water hoses.
Aug 02, 2009 | Washing Machines
Ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Jul 01, 2008 | Washing Machines
Washing machine stops after 5-6 minutes on my Whirlpool Duet front lloading washer and flashes F then H
FH is an indication the the machine is not sensing enough water flowing into the machine....
The only thing you can do without taking the machine apart is to disconnect the water hoses to the back of your machine and inspect the filter screens for any type of debris that might be restricting water flow into the machine. Typically, the cold water line is more susceptible to foreign matter than the hot waterline.
If screens appear OK then the problem may be with the water fill valve, water flow sensor, water pressure switch or blockage in the water pressure switch hose.
Jun 14, 2008 | Whirlpool Washing Machines
Machine not filling with hot water
First check the filters in the inlet hose and hot water pressure. Sounds to me like the hot water valve is faulty. Test the w/machine on a hot water cycle, if you hear a noise and its not filling it up with water,its a faulty hot water valve. Air pressure?? change the water valve and remember it has a little rubber boot on the old water valve, transfer this to the new valve,or go into option adjustment mode and change you wash temperature settings.
Aug 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
