Question about Dell 2200MP Multimedia Projector
Wont turn on
I have a dell 2200mp, had it about three months and now when it warms up the picture flickers and turns reddish, so i cleaned it out and now it wont even turn on.
  • DPoulos May 12, 2008
    Bottom 20% of image was growing dim. Removed bulb to inspect. Reinstalled bulb. Projector won't power up at all now.
  • 563 Answers
Hi kylemeadows
This most probably your Mainboard that will have to be repaired or replaced.
There is unfortunately not much else that can be done except for the above.
Posted on May 09, 2008
Clicking
the colorwheel needs replacing. the motor bearings are going. if the colorwheel slows down (due to bearings or interference) and doesn't sync up with the dmd chip, the pic will flicker until it does. also clean out the projector and see if there is any debris obstructing the colorwheel.
Aug 08, 2009 | Dell 2200MP Multimedia Projector
Dell 2200MP lamp turns off
Check to see if the fan is working, It maybe getting too hot.
Dec 28, 2007 | Dell 2200MP Multimedia Projector
Dell 2200MP makes a loud Humming Noise and vibrates
even if a fan spins it still can be noisy.clean all fans (i use a tooth brush).i also buy air in a can..(poundshop sells them).and spray them to clear any dust.when you have done that start the projector and see if is sorted...
Nov 02, 2017 | Dell 2200MP Multimedia Projector
Dell 2200MP Powers off
I have 2200MP projector that when you turn it on,it clicks about 8 to 10 times and then the power seams to turn on, but the lamp light light comes on and nothing lights up. it will shut down after that, with the green light still flashing. What could be the problem? Roger
Jul 28, 2008 | Dell 2200MP Multimedia Projector
Power Supply Unit of Dell 2200mp
first look at the dell site.
Then try to get your country dealer .
Before that contact your dealier
Jul 23, 2008 | Dell 2200MP Multimedia Projector
Dell 2200MP
Check that lamp cover microswitch closes (clicks). This microswitch disables the power supply when open. I had to bend the lever a bit to make it reliable.
Jul 21, 2008 | Dell 2200MP Multimedia Projector
Hi PFCS
Check out my answer to your other posting.
I would suggest you to at least get a quote first and then decide on what to do - chuck away - or - repair -
May 20, 2008 | Dell 2200MP Multimedia Projector
Dell 2200mp mounting screw
Hi wspy
If the look right next to the holes there should be a screw size written on the casing itself.
Apr 29, 2008 | Dell 2200MP Multimedia Projector
Purplish-reddish flicker on Hitachi
It seems you might have cold solder connections on the picture tube socket or on the picture tube drive board. If your not a tech please call someone to assist you with repair as you can be seriously hurt by the HI voltage insiode this set an or cauae more problems with the set. Good Luck
Aug 03, 2006 | Hitachi 43FDX01B TV
Dell 2200MP Multimedia Projector Logo
143 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
