Question about Ecoquest Living Air Classic Air Purifier
Dont get that ozone smell - Ecoquest Living Air Classic Air Purifier
  • 10,515 Answers
ou might be able to fix them.
There a couple of things that can go wrong with these units, dirty plates, bad contacts, and bad reostat.
Dirty plates:
The ozone is generated by the purification plates. They should be cleaned once a month with a solution of one part amonia and one part tap water. Use a soft bristle brush like an old toothbrush and scrub the metal contacts on the plates with the amonia solution. Be sure to do both sides. Allow them to sit with the solution for 10 minutes, then rinse off with tap water and allow it to dry completely.
Bad Contacts:
There is a couple of metal strips that make contact with the purification plate. Check the contact strips and wires for corrosion. The metal strips can also be cleaned with the amonia solution as well.
Bad Reostat:
The reostat is the part that attaches to the control knob that sets the purification levels. Sometimes it can go bad. The easilest way to check them is to use a meter and verify that as the knob is turned that the resistance changes with the position of the knob.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 30, 2010
Oh I have a an 880 Living Air Purifier. Just installed new plates. The Amber light is always on. Does this mean the ozone is working?
amber light indicates ionization, not ozone. ozone is generated only if you can smell it. You can fix your unit, trade it in for a brand new one or find additional help here: https://freshairpurifiers.net
Apr 20, 2018 | Air Air Purifiers
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
When I turn my brand new air purifier on on it smells like its burning or going to catch on fire is it supposed to?
That unit is a very heavy duty machine that uses ionization to clean air. There is a high voltage power supply that is used to generate ions. The unit can release ozone and that substance has a definite smell to it. If you have ever been near a copy machine or an electric motor that sparks, you would smell ozone. The concern is whether or not it is ozone. Ozone is regulated by the manufacturers to be held at a permissible level because at high concentrations it is an irritant and can cause respiratory issues by itself. The power unit for that air cleaner is on the top near the back and you can run the machine for a while to see if that area gets hot. That would be a bad sign. All the documentation is here: http://electronicaircleaners.com/f50f1032parts.aspx But if you don't trust the unit, take it or send it back.
Feb 20, 2016 | Honeywell (F50F1032) Air Purifier
How do I read the graduations on the purifier control & what do the 1 or 2 red plate settings tell me?
The graduations are incremental for your ozone output for the purifier control. Generally, the machine can put out enough ozone to cover 3000 sq ft. (when the control is moved all the way to the right, about 5 o'clock.) Half way should be about 1500 sq ft or 12 o'clock. For general air cleansing, you should set the purifier control to produce enough ozone so you smell it when walking into the room (after home) for about 30 seconds. The ozone smell should disappear after that. If it lingers, you've got it set too high. For more severe odor control you can set it higher but remember that some of us are more sensitive to the odor no matter what the setting. It may need some adjustment based on your individual preferences.
I'm confused about the 'red plates' as you mentioned. The original machine comes w/ 2 ozone plates (made of glass) and doesn't produce ozone when one of the plates is removed. I'm guessing that the lines may tell you when you're engaging both plates to work, i.e. more ozone being produced & blown into the room or less only calling on one plate to produce ozone. If you send me a close up pic of the control panel I may be able to tell you more.
Feb 24, 2014 | Alpine Air XL-15 Air Purifier
I no longer smell the ozone smell that i used too.
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers.
May 29, 2010 | Ecoquest Breeze AT Living Air Purifier
No ozone smell
May 19, 2010 | Ecoquest Flair Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
What to do to bring the ozone smell back
BE CAREFUL ozone is a well known lung irritant. just google it you should remove this product from you home now especially if you have asthma or any breathing issuses. If you dont have any you risk developing them.
Sep 09, 2009 | Ecoquest Air Purifiers
THE WET DOG SMELL
try soaking the grid plate in ammonia
Jan 11, 2009 | Ecoquest Flair Air Purifier
No ozone smell
This generally indicates that the plate is cracked or not making proper contact. Pull the plate and look very closely as even a tiny microscopic crack anywhere on the plate will produce these results.
Nov 08, 2008 | Ecoquest Breeze AT Living Air Purifier
Ecoquest Living Air Classic Air Purifier Logo
51 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
