Question about Desa International White Wireless Plug In Door Chime
I think I need to replace sender batteries which kind do they use and how do I get
  • 28 Answers
AAA size batteries.
Posted on Sep 01, 2010
Will not light up after replacing all batteries!
  • Remove all batteries
  • Install batteries in sender. allow time for sender to initialize and begin sending data
  • Install batteries in receiver. You should see temperature displayed
Sep 17, 2016 | Measuring Tools & Sensors
Where is the oil pressure sensor on a 1995 Chevy Truck? V-8, 5.7 L. I have the new one, just can't find the one I need to replace.
If you go to a parts store, I prefer CARQUEST, they will gladly print up a schematic or just show you where it is if that is all you need.
Feb 01, 2016 | Cars & Trucks
Moen motion sender kitchen faucet will not turn off
Disconnect the battery, count to 10 and reconnect it. If it continues to do it, the battery may need replacement, or it may need to be returned to a Moen Service Centre. Their warranty is excellent, 5 years I think?
Nov 26, 2015 | Moen Plumbing
How to change oil sender on a y reg 1.8t passat
Welcome to FixYa.com
in the location shown you will need a special oil sender socket.( you can buy at auto zone) and remove it and replace it. that simple. leedavidian_314.jpg
Thank you for Using FixYa.com Kind Regards, Lee Your FixYa Expert and Master Technician
Feb 06, 2011 | 1998 Volkswagen Passat
I HAVE A COLT 2.8 DIESEL TURBO CLUB CAB. MY TEMP GAUGE IS NOT WORKING. ON THE TEMP SENDER THERE IS TWO WIRES. WHEN I EARTH THE ONE WIRE THE TEMP GAUGE IS GOING FULLY UP. MY QUESTION IS WHAT MUST THE OTHER...
Dear Sir,
We can do one thing is that if temp meter goes up after wire connected to earth ,then please replace temp sender unit it will solve your problem, normally there no necessary for 2 wire at temp sender unit, if it is factory condition wire then let it be , if not then any technician had done that for other issue,replace sender unit your problem will solve 100%.
Thanks.
Oct 12, 2010 | Mitsubishi Colt Cars & Trucks
Fuel gauge doesn't work
Hi the reason the fuel gauge has stopped working is due to the sender in the tank packing up to replace this you need to lower the tank as the sender unit fits into the very top, you need to make sure their is no fuel in the tank as it will be to heavy to lower, its not the kind of job a novice can do.
please let me know if you need further assistance ok.
plz can you rate this post as i have a whole page of unrated posts, thanks
Aug 26, 2010 | 1998 Chevrolet C1500
No spark or fuel on my 92vw golf
check voltage to both coil and hall sender. should get battery voltage across two outer terminals on hall sender. battery voltage at black wire on coil. should get 5volts[pulsing] out put on center wire on hall sender. if input voltage ok but out put not, hall sender faulty. coil and fuel pump need an engine speed signal to activate.
May 25, 2010 | 1992 Volkswagen GTI
How to update the frame ware of our digital sender 9250c
the firmware probably does not even need to be updated unless you are having a problem
Dec 02, 2009 | HP Digital Sender 9250c scanner Printer
I need to replace the fuel pump in my 940 Volvo.
Disconnect battery ground strap before beginning to work on the fuel/electrical system. Do not smoke or have anything in the area which can ignite or cause sparks
  1. Drain enough fuel from tank to prevent spilling, no more than 4 gallons (16 liters) of fuel should remain. Use suitable pumping equipment.
  2. Remove floor mat and panel from trunk.
  1. Disconnect wiring harness connector to sending unit. Remove wires from connector.
  2. Disconnect ground wire to sender. Push wires through grommet.
  3. Remove cover for access to tank sending unit.
  1. All models: Disconnect from the fuel tank sending unit:
    1. Breather hose C
    2. Return hose A
    3. Supply hose B
    4. Filler hose D
    5. Wiring harness from clip E
  1. Clean area and unscrew fuel tank sender/pump cap or equivalent. Remove tank sender/pump and seal.
  2. Remove pump from sender/pump assembly.
INSTALLATION
  1. Inspect the pump for damage, feed pump hose and wiring for wear. Replace as needed.
  2. Install new pump to sender/pump assembly.
  3. Install rubber seal in neck of tank. Lubricate inside of seal.
  1. Install fuel tank sender/pump unit. Align it with the moulded joint (arrows) on tank.
  2. Apply rustproofing compound to exposed metal portions of tank sender.
CAUTION : With tape or rubber caps, protect fuel sender openings from overspray.
  1. Torque fuel tank sender/pump lock ring to: 22 ft-lb (30 Nm)
  2. Reassemble components in reverse order. Use tie straps to secure all hoses and wiring.
Jun 04, 2009 | 1995 Volvo 940
Fuel gauge erratic
Yes the tank has to come out. It really doesn't require any special tools. You should have everything you need at the ag dealer. Try to get as much fuel out of the tank before you start so it is easier to work with.
Jan 07, 2009 | 2005 Pontiac Grand Prix
Desa International White Wireless Plug In Door Chime Logo
26 people viewed this question
Top Desa International Home Security Experts
Steven R
Julian Pearson
Level 1 Expert
Mike
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
