My canon pixma /ip3000 printer isn't using the yellow ink, I have installed new ink tanks and ran clean and deep clean printer head and manually adjusted the color setting to max, did not correct problem. what's next ? Bill
Repeated deep cleaning (about 12 times) has started to get the ink flowing again, I am printing something every day and hope the problem clears up totaly.
Posted on May 09, 2008
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print.. cannon pixma ip3000
Ink has dried in the printhead. You need a new one, QY6-0064-000, around $50.00
Jun 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
No matter what color I choose to use, everything prints blue or black. My ink tanks are all full and are new. I ran the cleaning tools and the heads are open but all the colored stripes were shades of...
remove the print head . soak in isoprople alcohol 91%proof. do not touch the gold pads in back of the print head. do not push hard on the head with the soft cotton cloth as tiney fibers of cotton may clog the heads further. let soak 5 minutes at least. then air dry and replace in printer and run clean cycle or deep clean cycle . then print a test page again. you might want to wear rubber gloves for this... ps clear house hold amonia helps cut the ink if you get it on anything
Feb 20, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
IP3000
canon ip3000 & ip4000 the heads get dirty.
if you keep doing cleanings and deep cleanings it will eventually cause an error because it thinks the tank is full.
take out the head - in the sink, with warm not hot water rinse out much ink as possible. then use windex, the ammonia removes the ink. flush good - shake out head, drops will form on the bottom. keep doing it until drops are clear. rinse with water. shake out well. dry contacts.
I use a water pic as a pressure washer to force water thru. replace head and tanks.
do not use clean, instead print a page of 'X's
make every 5 rows a different color. this way you can see what is working and it won't fill up the cleaning tank, causing a code error.
you can use any ink you want as long as it is the proper type- don't have to be canon
Sep 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
My printer is a Pixma IP3000 I can't get the yellow ink to print
Take out the cartridge and inspect it... have you removed all the protective tape. reinsert it and make sure it is in correctly (the same as the others)
Robert
Aug 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Ink not working properly on ip3000
clean the printer so the ink will come out. Don't worry i had the same problem trust me this works!!
Hope it helps
Jul 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Bad colors in print
perfrom a deep head clean 2 times this will clean the printer printer head out. make sure u have heaps of in in your ink tanks as it uses a bit of ink to clean the heads out. then try and do a print. also you may need to do a head alignment on the printer. this head alignment should be done after u replace ink tanks.
the only other item it could be is the print head on the printer.
Nov 20, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
267 people viewed this question
k24674
jasbo
jasbo
