Can not get dtv to work on my phillips tv how can i reset it so its like i have just plugged it in
  • 4,102 Answers
Hi depending on how you have got it plugged into the telly would depend on what button you press on the remote to choose the correct channel,
on the remote you will have one of the following buttons
av
input
source
ext
or picture of a rectangle with arrow running from left to right
you will need to press one of these buttons so as the tv goes onto the right input channel now you may need to press it more than once as it depends on how many inputs your tv has
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 30, 2010
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
My Philips LCD TV (26PF7321) is stuck in DTV mode, cannot access most menus, please help?
I would contact Phillips customer service by phone and see if this a issue common to this set and if there is a way to either do a hard reset or a software upgrade to resolve this problem.
Mar 19, 2012 | Televison & Video
My phillips tv will not turn on. the blue light will stay only a second.
Try reset the TV first by unplug from the wall for 5 minutes. Then plug in power and turn on again to see if the firmware loads for DTV tuner. If not, you need service..Most large TV LCD screen maybe bad(short circuit), so that TV will not work.
Aug 26, 2010 | HP LC3760N 37 in. LCD HDTV
New phillips tv model 42pfl7403d/f7. remote quit working. Also dtv remote not working either.
then i would say the remote diode in the tv has malfunctioned. you will have to have it tested and replaced.
Aug 03, 2010 | Philips Televison & Video
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
I have phillips flat tv 42pf7520d and can not switch from dtv to analogue, button not working but tele registing it as lights up, no picture through the dtv and sky wont even override the tele
This is a commong fault on that model, you will either have to have the mainboard re-programmed, or replaced.
It has lost it's "memory" as it were.
Sep 01, 2009 | Philips Televison & Video
Vizio LCD DTV 32 inch. Model L32. I can't 'scan' for digital channels. When I go to DTV, then Menu and scroll right or left to "TV tuner setup' I get a blue screen and nothing else. No key on the...
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Mar 23, 2009 | Vizio L32 32 in. LCD HDTV
DTV Question
Called the company that makes the TV.
Jan 21, 2009 | Tvone (1T-DVI-YPBPR) Analog to Digital...
Zenith TV
automatic code search. this may take a while to do but it works. hold the directv button and tv power until the red light stays on. while its on press the channel up button (this will search for a code). release and test with the tv power button. if the tv does not turn off, press the channel up button again and test with the tv power. when the tv finally goes off, press the enter/last button (bottom right corner of the remote) to store the code
Aug 31, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
