Question about Samsung SW62ASP Top Load Washer
Rattling sound and vibration while spinning - Samsung SW62ASP Top Load Washer
  • 2,272 Answers
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. The other possibility can be faulty motor causing the bearing to rattle/. Check out both the motor as well as spin bearing. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Sep 23, 2014 | LG WM2487H Front Load Washer
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
Rattling noise sportage 2008
Sorry for the late reply but, no, it is not related to a loose heat shield. It is a louder rattling sound more like a loose bearing vibrating inside either the transmission or the clutch assembly. Only between 1600 and 1900 rpm. and it is not present under ou over these rpm. The rattle desappear when I lock the 4X4. Dealer is out of solution!!
Aug 06, 2012 | Kia Sportage Cars & Trucks
Back wheel rattles when u spin it back and forth and also vibrates when i pull the throttle back going along but its not the bearing in the rear wheel as theres no side to side wobble or play please help...
Sounds like a collapsed or near collapsed bearing. While rocking it from the top forward and back is a good indicator of bearing wear. So too are vibrations and rattles from the wheel. It could also be the anti vibrational cushions assuming your bike has those, that are present in the back wheel. They soak up the to and fro backlash that you would normally get when accellorating.
Sep 18, 2011 | Gilera Runner VX 125 Motorcycles
My car is a 99 with 177K miles. It has been a great vehicle but now I am getting a rattling and vibration sound coming from what seems to be the right rear wheel. I have looked underneath and have pretty...
i have read what you say and can only come to the conculation that you have a rear buckled wheel.i had the same problem a couple of years ago and found a bulged tyre ie a bulge on the inside of the tyre and it caused the same problem.adrian,,,
Sep 02, 2011 | 1999 Toyota Camry Solara
Makes loud rattling sound in spin cycleloud and
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2009 | Kenmore 24032\24036 Top Load Washer
LOUD RATTLING NOISES ON SPIN CYCLE (SOUNDS LIKE MONEY OR MARBLES IN MACHINE)
you'll need to investigate further. It may even mean bringing in a professional to be sure the vibration damper rods are ok - to prevent future and costlier problems.
Jun 01, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
New washer rattles and vibrates when on spin cycle.
did you remove the yellow tab at the pack to pull the shipping pins check your owners manuel under installation for details let me know
Mar 30, 2008 | Whirlpool GST9679P Top Load Washer
Samsung SW62ASP Top Load Washer Logo
372 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
