Question about HP Compaq Presario v3000z Notebook
Laptop with serial ports
I am needing some laptops with serial port and as possible paralell port.
paulo.qualitel@msn.com
  • qualitel May 09, 2008
    I can't use adapters I need laptop with serial port like a toshiba tectra A3 or HP NX9040.
  • 1,031 Answers
You can get it in IBM thinkpad or HP Compaq nce6320
Posted on May 08, 2008
  • Starnley Johnwells
    Starnley Johnwells May 08, 2008
    USE PORTREPLICATOR FOR IBM THINKPAD T40 SERIES
    Champion:
  • 230 Answers
Try ebay
I have the same printer, and xp on my pc, but how do i connect them? my laptop does not have a serial conection. i tried to use a usb/serial converter and i installed the xp driver from minolta website,...
You need to make sure you have selected the correct COM port whin you try to print. Depending on the type of USB to serial converter, the COM port it assigns can change just by moving it to another USB port. Right-click on My Computer and select MANAGE. Select Device Manager from the list. Click on the (+) next to PORTS and double-click on your USB-SERIAL device COM port. Somewhere in the Properties window you should be able to see the assigned COM port (COM1, COM2, etc.). If possible, set the COM port to COM1 or COM2 for greatest compatibility with older software. Then when you print, make sure your printer driver is also set to the same COM port.
Mar 05, 2011 | Office Equipment & Supplies
CANT GET PARALELL PORT TO WORK DEVICE MANAGER DOESNT SEE IT ?
the laptop bios should support lpt port and if your doesn't have lpt port then you can not use the one for the docking station because no bios integration with the lpt port on docking station
Apr 18, 2010 | Targus Port Replicator, Docking Station,...
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Datamax I4212 printer is dropping characters on large prints jobs from Easylabel. Any idea why?
If you are using serial port (COM1), problably your cable doesn't have flow control. You need a cable that use RTS,CTS and DSR. If you are using paralell port, make a change to serial port.
Nov 19, 2009 | Datamax DMX-I-4212 Label Printer
The media is in correctly and is being fed correctly but when we sent a label from our computer to the zebra printer it will not print the information on the media. Was fine a few days ago.
send a test print from the driver.
check the connection configuration.
if connect with serial port (check seting from the port (THE SPEED HAVE TO BE THE SAME)
if connect with USB, if necessery, install the driver again and test.
if necessery flash the firmware and test (worst case scenario)
if can't comunicate and if using paralel port:
check if the fuse next to the paralel port is burn ( on the logic board.). replace it.
dont forget to unplug the power cable and the comunication cable.
Nov 18, 2009 | Zebra 110XiIIIPlus Label Printer
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Oct 07, 2008 | Canon Office Equipment & Supplies
Connecting my HP ScanJet 5200C scanner to my HP Pavilion Home pc
Rookssailor,
I don't think you can (successfully) run this scanner off the paralell port. I'm drawing on memory here but I think this scanner has serial and usb ports. If you are running Windows XP, use the USB hookup. If you are running Windows 95, 98, Milliniaum then you might want to use the serial port. At any rate the scanner software should be installed before you plugin the scanner.
If I'm completely "full of it" and you really want to use a Paralell connection then you might want to use a paralell to USB adaptor (Belkin, perhaps others make one of these).
haMAR
Apr 01, 2008 | Office Equipment & Supplies
Sister, has given me her old HP Deskjet 690C printer but I do not know how to fix a port onto my Higrade notebook (Windows Vista)
If it's because your laptop does'nt have a paralell port you can use a Paralell to USB adapter cable.
Have a look on EBay.
http://search.ebay.com/parallel-to-usb-cable_W0QQ_trksidZm37QQfromZR40
Mar 17, 2008 | Computers & Internet
Usb ports on a toshiba satellite pro m15-S405
You can if you have good soldering skills. The welds are located on the opposite side of the motherboard. Just go to partstore.com or ebay to find a raw module to replace it. Otherwise you must replace the motherboard. Remember, heat the work not the solder, and use low watt if lots of smaller circuits are closeby.
Jan 06, 2008 | Toshiba Satellite Pro M15-S405 Notebook
HP Compaq Presario v3000z Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
